Old 05-15-2011, 09:37 PM   #1
Toxic Redline
Toxic Redline's Avatar
PROJECT "As Seen In My Garage"
Ok so i finally decided to do a build thread on here.
so a two years ago i bought a 1984 Chevrolet K20. 383 Stroker, Hooker Comp Headers, Edlebrock performer intake, 2 Inch body Lift, faded paint, minimal body cancer, 4x4, hi-flow water pump. I had always wanted a square body, my dad had some when i was younger but sold them before i was old enough to drive.
Soon after i got it and started body work
84 K20 Long Box W.I.P
78 Burb - parts now [Rolled]
68 c20 dump bed
WHEN IN DOUBT--- FLOOR IT
Toxic Redline is offline   Reply With Quote
Old 05-15-2011, 09:42 PM   #2
Toxic Redline
Re: PROJECT "As Seen In My Garage"
Next i started to do more body work and i primered the whole thing black for winter because i dont like body work in the cold I put a 4 inch lift on for a total of 6 inches of lift. Then i started haveing clutch problems. i put a new clutch in and kept on ruining throwout bearings, after some research i found it needed a long shaft throw out bearing. I put one in and it worked. (tranny dropped 4 times by this point.
68 c20 dump bed
Old 05-15-2011, 09:47 PM   #3
Toxic Redline
i traded for two new front fenders and started body work again. Then i started haveing motor issues. My harmonic dampner broke so i had to get a new one. those arent cheap. After that my timing kept on getting messed up, dont know why, then i started having issues with the rocker arms and heads,. i did not know what clearence they needed to be so before i ruined the whole motor i traded it for a 350 small block that would not need so much tlc and get better gas milage, by this point i decided i wanted a daily driver not a race truck.
68 c20 dump bed
Old 05-15-2011, 09:53 PM   #4
Toxic Redline
that is my new motor and centerforce clutch. It took me awhile to get it together. (school and a little burned out) but i finally got her together and took her for a test drive...... and ruined a throwout bearing. so i got a new throwout bearing, and for some reason it is not working, i dont know what kind of tranny is in my truck but im done messing with it, so yesterday i pulled the body off my suburban (it had been rolled) and i am going to put that tranny in my truck, that way i know what exactly is in my truck and i dont have to play this dumb guessing game........
68 c20 dump bed
Old 05-15-2011, 09:55 PM   #5
Toxic Redline
A side note dont buy the extended brake lines from Autozone because they dont stock them anymore and it takes them a month to tell you!!! fetching ridiculous!!
68 c20 dump bed
Old 05-18-2011, 11:39 AM   #6
Toxic Redline
I've decided that i will use the transmission out of the burb because i will not have to play the guessing game and that tranny has the " Bulletproof" NP205 Transfer case that i have always wanted
68 c20 dump bed
Old 05-31-2011, 01:09 AM   #7
Toxic Redline
pulled the tranny out of the burban and cleaned her all up and got her painted 30+ years of fossilized grease is now gone looks pretty nice
68 c20 dump bed
Old 05-31-2011, 01:11 AM   #8
Toxic Redline
after that i got the burb frame cut up and ready for the scrap yard saving the axles and motor even though the motor needs a complete rebuild and almost everything,,,, might end up scrapping it for money
68 c20 dump bed
Old 05-31-2011, 01:57 AM   #9
makman1297
makman1297's Avatar
Looking good, i always liked the 3/4 tons better.
makman1297 is offline   Reply With Quote
Old 06-02-2011, 07:36 PM   #10
Toxic Redline
Got some 37" Wranglers just got done putting them on the rim, now to pay for balancing
68 c20 dump bed
Old 06-10-2011, 10:04 PM   #11
jonesky2
jonesky2's Avatar
keep it up! I want to see this thing with the new shoes.
jonesky2 is offline   Reply With Quote
Old 06-13-2011, 05:25 PM   #12
Toxic Redline
the new shoes not on yet cuz jones hasnt got me the hookup
68 c20 dump bed
Old 06-13-2011, 05:27 PM   #13
Toxic Redline
Found a sweet tach instrument cluster cant wait to get it in
68 c20 dump bed
Old 06-13-2011, 05:29 PM   #14
Toxic Redline
it was all in one piece but im using some other guages for the amps and temp and the oil pressure o and i set back the milage now my truck has no miles on it
68 c20 dump bed
Old 06-17-2011, 09:19 PM   #15
Toxic Redline
need a longer driveline!! why do the junk yards bend all of them!!
68 c20 dump bed
Old 04-13-2014, 01:38 AM   #16
Kapote
Kapote's Avatar
Smile Re: PROJECT "As Seen In My Garage"
Ok we'll I'm formerly known as Toxic Redline but after being out of the country for two years I've started up my 84 project again' before I left I got rid of that 350 so it just didn't rot, so now I've been looking for a new motor but I ain't got no money, so I got a deal' a 64 dump truck that they put a crate 350 that has 70'000 on it now and I get it free I just have to put the trans in a different truck, so I dropped the trans and fired up the motor today needless to say IM PUMPED!!! Good to be back
Kapote is offline   Reply With Quote
Old 04-13-2014, 10:25 AM   #17
Zane M
Looking forward to seeing some more progress.
Zane M is offline   Reply With Quote
Old 04-13-2014, 11:51 AM   #18
rusty76
rusty76's Avatar
I'll be watching along for the ride. Waitin on updates.......
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 04-13-2014, 09:52 PM   #19
Hankster
Hankster's Avatar
I'll be watching this one!
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 04-18-2014, 11:51 PM   #20
Kapote
Kapote's Avatar
Ok so the trans is out and motor is all loose except for the motor mounts hopefully I'll get the loader and pull the motor tomorrow !
1984 k20 "Project as seen in my garage".
1968 C20 -292 dump bed
1987 Burb, 350TBI 700R4, RedNRusty
Old 04-19-2014, 09:29 AM   #21
aotte1
Very nice project, with lots of innovative work. Been to Ogden many times, great scenery, and better skiing, Powder Mountain. Keep up the reports to us.
Do you have any " government liquidation" sales in your area, sometimes they have unique 4x4 stuff. We are driving a one ton 4x4 CUCV as HD truck which includes trail making through the woods, it is amazing how far you can go just crashing through the woods with it. Also have CUCV Blazer made from 6 parts blazers. They have cool things like M16 gun racks, black out lights, jerry can holders, spot lights, places for electronic gear, dual battery and alternator set-ups, and almost crash- proof bumpers.
Thanks for sharing your project with us. Please keep reporting.
Les
aotte1 is offline   Reply With Quote
