Old 05-15-2011, 10:02 PM   #1
kilomanjaro
kilomanjaro's Avatar
np205 Rebuild Question....Idle Shaft
I just installed the idle shaft and gear in the np205 I am rebuilding. I know you are supposed to install the shims and spacer between the bearings and check the end play. I thought I was good with zero end play, but then I installed the idle gear/shaft into the case and torqued the shaft nut to 135 lb.ft (also read it is supposed to be 200) I installed the same 3 shims that came out of the assembly. I had new races put into the idler gear. When I tried to torque down the nut it just froze the gear assembly. I backed off the nut and reset to about 75lb.ft. It spun freely without any binding and there was zero end play in the gearset. Do I need to pull it out and add a shim so I can torque to 135 (or 200) lb.ft? Advice from anyone with some experience here would be much appreciated. Thanks
John
63 Buick Wildcat 425
72 Chevy Blazer CST
72 Chevy C10 Cheyenne
00 Ford F-350 Super Duty 7.3L
09 Dodge Challenger SRT-8
10 Ford Expedition Limited
kilomanjaro is offline   Reply With Quote
Old 05-17-2011, 10:56 PM   #2
jbclassix
Junk Yartist
jbclassix's Avatar
Re: np205 Rebuild Question....Idle Shaft
.001-.002 end play. 135lbft.
There is a spacer sleeve that goes between the shims and one of the bearings. Do you have that installed?
-Jeremy
YOU ONLY FAIL IF YOU STOP TRYING
70 Crew Cab Build Link
70 GMC Suburban 4X4 build thread
95 Yukon Daily Driver
Rebuilding an NP205
jbclassix is offline   Reply With Quote
Old 05-17-2011, 11:13 PM   #3
kilomanjaro
Yes I put the shims in, I ordered some more shims last night from some website....quad 4x4 I think.....$35!!!...I need to add some to get the space between the bearings set right. I'm not sure why I need so much more shim after putting new races/bearings in.
John
72 Chevy Blazer CST
Old 05-17-2011, 11:22 PM   #4
jbclassix
Junk Yartist
jbclassix's Avatar
I was referring to the sleeve that is pictured between the shims and the bearing. without it the bearings will just LOCK when the nut is torqued. Hope that helps.
-Jeremy
Rebuilding an NP205
Old 05-17-2011, 11:50 PM   #5
kilomanjaro
Yes I put the sleeve in too....the bearing races must be a little different somehow. thanks
John
72 Chevy Blazer CST
Old 05-17-2011, 11:57 PM   #6
jbclassix
Junk Yartist
jbclassix's Avatar
You may laugh at this picture, but this is how I pre-loaded my bearings to set my shim pack before installing it. I am almost done rebuilding my 205. I photo documented the whole thing. I will post them up once it is all back together.
-Jeremy
Rebuilding an NP205
