Old 05-15-2011, 11:06 PM   #1
KyleL113
1970 c-10 Brake sticks after parking overnight
As the title says i have a 1970 c-10 non-power drums all around. After parking overnight the brakes seem to be stuck, at first i thought it was e-brake related but i left it on flat ground in gear and the same thing happened the next morning. after driving an 8th mile or less they feel completely freed up. (i hope)
any ideas?
KyleL113 is offline   Reply With Quote
Old 05-15-2011, 11:28 PM   #2
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
Re: 1970 c-10 Brake sticks after parking overnight
have you went over them? or is the entire system40 years old still?
John
1999 Toyota Tacoma 4x4
Old 05-16-2011, 09:49 AM   #3
cdowns
cdowns's Avatar
i'd park it for the night with the thought of jacking it up in the morning b4 using and removing the tires and brake drums and inspecting the brakes b4 using to see if in fact it is your brakes causing drag
Old 05-16-2011, 07:32 PM   #4
KyleL113
when it feels stuck after sitting in rolls fairly easily backwards but not forwards. any ideas?
Old 05-16-2011, 07:33 PM   #5
DaBigKahuna
DaBigKahuna's Avatar
WAG... brake adjuster stuck?
DaBigKahuna is offline   Reply With Quote
Old 05-16-2011, 07:55 PM   #6
KyleL113
if feels like the front right wheel but i wont know for sure until i can check one morning before work. how can i see if the brake adjuster is stuck. what is WAG
Old 05-17-2011, 01:49 AM   #7
DaBigKahuna
WAG=Wild Ass Guess
It's been 30 plus years since I've worked on drum brakes so maybe someone else might be better to answer. I'd make sure that the adjuster was spinning freely that the threads aren't binding and the mech that moves the star was working.
One thing that my be interesting to test... does it act differently if your last stop is rolling forward or rolling backwards.
Old 05-17-2011, 02:57 AM   #8
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
when you take the drums off i would take some emery cloth and buff up the shoes ,most likey the shoes are holding moister in the material ,also check for the wheel clyinders for seepage ,take a picture and post it up i'll inspect it ,look for grooves in the drum and measure them for run out .
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
