Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 05-15-2011, 11:55 PM   #1
dbmx66
light weight front suspension
lookin got get a couple pounds of the front end of the truck.
got a new job, more money so i wanna re do my front suspension.
like put on either strange struts ( i already hate the strut towers coming through the fire wall)
or get some good tubular control arms with adjustable coiler overs.
im also going to remove the factory crossmember and weld a tube in there to take its place and gusset it for strength. i want to loose as much weigh in the front as possible.
i have motor plates so im not worried about loosing the factory engine mounts. ( i know i need the engine limiters )
also gonna switch to rack and pinion
what kind of set ups are you guys running?
thanks
dbmx66 is offline   Reply With Quote
Old 05-20-2011, 01:02 PM   #2
kwhite4
Junior Member
kwhite4's Avatar
Re: light weight front suspension
Fatman Fab makes a bolt in kit that sounds like what your looking for.
DJ has one of these on his truck and seems very happy with it, Im sure there are many different companies making simular products but this one seems to be very easy to install and maintain.
I wish I had a few extra bucks to throw at one of these myself they say you can lose up to 200 pounds off the front.
Keith
68 GMC
565 BBC
Abruzzi super pro glide
9.85@135.00
kwhite4 is offline   Reply With Quote
Old 05-20-2011, 10:11 PM   #3
Notch1988
Notch1988's Avatar
And if you're looking for the last little bit of weight you can get hollow bolts to put it all together.
Notch1988 is offline   Reply With Quote
