Steering wheel size
anybody know what the size of a factory steering wheel is for a 1967-72. Mine has a grant 13inch that seems a tad small for me. anyone have any suggestions on a size 14,15, don't want to get to big
Pete The worst I ever had was wonderful ![]() 69 SWB work in progress 97 Ranger 6in. lift on 35's 04 325i lady's ride |
Re: Steering wheel size
The original one I believe is 17"
1969 CST-10 Stepside ![]() 1971 C-10 Short Fleetside ![]() 1967 GMC 3/4 Suburban 4x4 ![]() 1972 C-10 Longbed |
I think a 15 inch should be about right for me then. Thanks
anyone else have any advice???
member #16
![]() Join Date: Dec 1999
Mine is a camaro. 14-1/2"
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Thanks for the picture john, i was going to ask you for one. I like that, that 13in. in my truck is a little to sall for me
![]() Join Date: Feb 2011
This is what I used...15" Left hand does tend to hit the turn signal stalk, but it's a minor adjustment.
MusicMan70 1961 GMC Suburban |
is that an original next to it. whats the difference in the sizes?
Original wheel yes and about an inch or more diff...
thanks
You might also check into the Chevelle/Camaro/Vette 3-spoke cushion grip wheel. It kinda gives a factory look and it's only 15" I wish I had a pic to show you, but I don't. Maybe someone will chime in with one.
thinking about this one. 15 inch moonseye. Still want to check out some camero's chevelle's and others
The factory wheel was an issue for me as with my big belly I was not comfortable with it then I chenge the column to a tilt one and went with a 73- steering wheel then I switched to an 88-95 chevy truck wheel which is the one I have now and it looks pretty good in there. I even had a grant steering wheel at the very beginning, steering wheel has been a pain for me to find out that I like even though I lost close to 40 pounds so now I wish I had my original one back on..
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
#13 |
I like everyone of those. thanks for the pics
#14 |
Musicman, that wheel looks great, has an "older" look after you re-did it. Whats the wheel from, how did you hook it up?
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
#15 | |
I don't have a tutorial but I do have some pics of the wiring. A part of the plastic needed to be trimmed (pics 2,4) for the wheel to fit properly. Also the Plunger mechanism (brass ring) for the horn had to be dismantled and inverted(I think), spliced and fed through the hole, to spade connector(added by me) to the horn button itself. The plunger has a constant metal contact with that ring via an internal spring. Also removed the Turn-signal arm and carefully bent it back a bit. I just sorta worked it out on my own and only took these few pics of the end wiring. Hope this helps.
#16 |
Last pic of inside horn cap, connect here.
#17 |
14" chromed billet, I think it's a pretty good size
![]() ![]() Posted via Mobile Device
1972 Pale Yella 2WD Blazer ..... 350HO/700R4.... '68 Clipped 1970 Original Paint SWB Farm Truck ..... 5.3/4L80.... 2x HRPT Participant |
#18 |
![]() Join Date: Feb 2002
Original 3-Spokes .....'67/'68 =16.5" O.D.
Original 2-Spoke........'69/'72 = 17" [or 17.5" ?] O.D.
#19 |
Hello, I'm looking at getting this one from eBay - Does anyone know if this will fit?
http://www.ebay.com/itm/1969-72-Chev...f2515f&vxp=mtr Thanks |
#20 |
![]() Join Date: Dec 2006
14" billet wheel works great with power steering. I've had them in several trucks with no problems.
Follow me on Instagram: @midtennc10 Youtube channel: Midtennc10 |
#21 |
Found this one and I'd like to do the same... Was trying to find the model and what I need to make it work.
http://futureclassicsnj.com/closeup....page=58&a=2594 |
#22 | |
Posted via Mobile Device |
#23 |
Here's mine. Repro 15" '55 Chevy, with a little artwork.
'92 GMC Suburban 1500. 153K miles (when purchased), super clean inside and out. '67 C10 swb. 350/700R. Solid TX truck. |
#24 |
The wheel Music man 70 said was from Astro/Safari van was also available on the S/T trucks and Blazers from 86 When they changed the dash from the flat to the one with the cluster "bump" on it to 93[86-93] the plainer models had them and If I knew then [20 something years ago] when I was building the S trucks by the ton that those wheels would come in handy I'd saved more of them. The same goes for the 88-94 sport wheel [4 spoke] that lots like to use on their trucks. I probably threw a hundred of them in a dumpster when I got rid of most all of my 88-98 parts. DUH. Jim
#25 |
Old member
Here is a Corvette wheel. I took it off in favor of a 67 SS Chevelle wheel though.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
