Old 05-16-2011, 08:21 PM   #1
bruin_d
bruin_d's Avatar
Entropy radiator setup
Are there any BBC guys out there running the Entropy radiator with the dual fan setup that he sells? They look nice and more importantly in my price range. I'm mainly curious if there is room or not.
bruin_d is offline   Reply With Quote
Old 05-16-2011, 09:31 PM   #2
weircc
weircc's Avatar
Re: Entropy radiator setup
alot depends on which mounts u use i have the tubular mounts with short pump and it fits (tight) but i changed my fans to slimmer ones if u run stock mounts fits with short pump no problem. for some reason tubular mounts push motor forward they say for hei but didn't see any reason why hei wouldn't fit with stock mounts cause now i can fit 2 hei's lol
weircc is offline   Reply With Quote
Old 05-16-2011, 09:34 PM   #3
Painter D
Painter D's Avatar
Yes there is plenty of room for the big block.
BTW their stuff is very nice, I'm running one of their dual fan setups w/aluminum shroud, and I have a big block.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs)
'63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs)
http://67-72chevytrucks.com/vboard/s...=528853&page=5
Painter D is offline   Reply With Quote
Old 05-16-2011, 10:16 PM   #4
danman987123
danman987123's Avatar
i am also running entropy setup......great product and great guy
danman987123 is offline   Reply With Quote
Old 05-16-2011, 10:44 PM   #5
bruin_d
bruin_d's Avatar
I'm running the mounts that came with my drop member, not sure which way they push the motor. So I'm guessing there is no chance a long water pump will work?
Old 05-16-2011, 11:06 PM   #6
weircc
weircc's Avatar
i would say u would be ok maybe order without fans cause u can get slimmer ones just in case but his fan really throw the air
Old 05-17-2011, 05:39 PM   #7
bruin_d
bruin_d's Avatar
In case anybody was wondering, for $150 more he will use lower profile 14" fans. I'll let everyone know how it comes out.
Old 05-17-2011, 06:07 PM   #8
Jacfourteen
Big Red - Now its a SWB!
Jacfourteen's Avatar
I don't know about fitment because I'm running a sbc, but I know that it is a quality rad and that it cools well. Last summer the temp hit 110+ degrees around here and as long as I was moving 10 mph or more the fan would never come on and the temp would stay right at 160. When I was stopped the fan would come on after about 5 minutes and keep it right at 160.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread
41 3/4 ton (wife's)-flatbed, fully restored to original
01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's
02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's
Jacfourteen is offline   Reply With Quote
Old 05-17-2011, 07:36 PM   #9
Painter D
Painter D's Avatar
I'm runnin a long water pump on my big block, there's still plenty of room.
Old 06-06-2011, 05:48 PM   #10
bruin_d
bruin_d's Avatar
How long did it take you guys to receive your radiator? I'm getting close to a month now...
Old 06-06-2011, 07:32 PM   #11
Painter D
Painter D's Avatar
About a week.
You may want to contact them to see what's going on.
Old 06-06-2011, 08:41 PM   #12
weircc
weircc's Avatar
Originally Posted by 69chevyshort View Post
About a week.
x2
Old 06-07-2011, 02:00 AM   #13
Jacfourteen
About a week.
X3
Old 06-07-2011, 10:31 AM   #14
ivanuf2
ivanuf2's Avatar
Great radiator, great fans and wire harness.
ivanuf2 is offline   Reply With Quote
Old 06-14-2011, 07:02 PM   #15
thor
thor's Avatar
this radiator and fan set-up looks bad a$$. quick (slight hijack) question - is the sbc and ls upper radiator hose connection the same size? reason I ask is I'd love to do an ls swap but money is tight and installing the radiator first, and then the engine, would make the swap cost easier to do...a lil at a time. thx!
1972 Chevy Blazer CST.....Project: Polished Turd
thor is offline   Reply With Quote
Old 06-14-2011, 09:14 PM   #16
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
x4. The website said "processing" a week after i ordered mine, and the money was already taken from my paypal account. I contacted him and he said he didnt have a chance to update the website and it was set to go out the next monday. Took around 2.5 weeks altogether i think. Worth it when it showed up though, awesome quality handmade in the USA...
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 06-24-2011, 12:04 PM   #17
thor
thor's Avatar
Here's some info I found...
LS has 1-1/4" top & 1-1/2" bottom rad hoses
SBC has 1-1/2" top & 1-3/4" bottom rad hoses
