05-16-2011, 09:56 PM | #1 |
2 quick quetions
Before I pick up the 1970 C20 on the weekend I had 2 questions.
What TYPE of fuses do I need for the truck? I assume it is the stock fuse block. I know the tail lights aren't working as the seller mentioned they are not working, but not sure what type of glass fuse I need. Could be just a bad ground but I want to bring one with me when I pick it up. Also, what size are the wipers on the truck. At least one needs to get replaced so I would like to get some new ones, especially if I want to get it certified to transfer the ownership to my name.
Mike Email: Click here to email me -- 2019 Silvedrado 4x4 1970 Chevy 3/4 ton, 396BB, on air bags |
05-17-2011, 03:13 AM | #2 |
Re: 2 quick quetions
Most fuses should be AGC and SFE style glass fuses. Amps depends on the app.
When I replaced my wipers, it called for 15" blades. I was able to use the metal blade holders and just get a set of replacement blade refills. The store only went as short as 16", but they fit fine.
68 Chev C20- son has it now 83 K20 - bought from son 70 C20 - in progress |
05-17-2011, 06:30 AM | #3 |
1969 Custom 30 wrecker
I think it's a 20 amp but don't hold me to that. I'd take a 10, 20 and 30 to be sure.
If it blows it right out, you have a short somewhere, probably just a pinched wire somewhere. Have fun!
Bob 63 Impala 283/PG/3.36 (under restoration) 66 Impala 327/PG/3.36 66 Chevelle SS 409/M22/3.55 69 Chevelle 307/PG/3.08 (future restoration) 69 C10 short stepside 454/TH350/3.73 69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!) 71 Cheyenne 20 fleetside 350/4 spd/4.10 71 Chevelle 6/PG/3.08 72 Chevelle 454/M21/4.10 |
05-17-2011, 06:49 AM | #4 |
since I dont smoke I always found the ash tray a handy place to keep those spare fuses since I almost never rememberd to replace any spares in the fuse block !
05-17-2011, 08:28 AM | #5 |
Good idea for the spare fuse location. As for the tail lights. If the fuse is good, it could also be a bad ground. I had that issue back when I had my 69.
I will take a few spare fuses and a meter with me just in case. Posted via Mobile Device
