Old 05-16-2011, 11:27 PM   #1
yfz450_0569
Brake/Throttle Pedals
I've been looking around on ebay and Summit and even googled some stuff and can hardly find anything I like. I'm using a hydro-boost set-up for my brakes if that makes a difference. I've even thought about building myself something, but not even sure where to start. I would really prefer to buy, but if I had some plan or some pictures to go off of I wouldn't mind building one either. I appreciate any ideas...
yfz450_0569 is offline   Reply With Quote
Old 05-17-2011, 09:41 AM   #2
yfz450_0569
Re: Brake/Throttle Pedals
Nothing??
Old 05-17-2011, 10:24 AM   #3
charx2
charx2's Avatar
I thought about building myself one. I was going to weld on a small bracket onto the pedal linkage and then weld on a pin to the pedal pad. That way the pad can slip into the pedal linkage and then keep it there with a cotter pin or something. Just a thought. Probably didn't make much sense because it's still in the "just a thought" process.
My 67 c10 Thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=409192
charx2 is offline   Reply With Quote
Old 05-17-2011, 10:48 AM   #4
yfz450_0569
I also thought about doing both the brake and the throttle "hinged" on the same pipe/rod up top so they both look similar, and then just doing the top part different. I'm sure there's a reason why I've never seen that done..
