brake line kits
i need front brake line kit for my 69 long horn. where is the best deal at or does somebody have any they would make me a deal on
Re: brake line kits
I used the one from the truck and car shop in orange. It only worked okay, I still felt like I had to do a lot of bending and modding. I'd almost recommend making a template out of wire then making the lines manually. Other vendors like LMC or ECE might be a bit better. In the end, mine did work fine, but just my .02
Have mercy, I'm recovering from my 4x4 addiction. ![]() |
Re: brake line kits
The pre bent ones are expensive if I remember correctly. I just took some #8 solid ground wire and made a template, then bought some line and borrowed orielys flange tool, had a cheapo line bender from harbor freight and made them off of the prebent wire. Some were to long so I cut those and reused the fitting after bending into place. If you don't want to go that route, check with some venders first, them check lmc.com
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
Scrapper 1
the one i have to say about this.Is i would of like if GM would of cleaned up and made it really defined about running the brake lines up to the power brake unit Have a horrable time trying to reach the Oil dip stick them lines don't need to be all over the place keep them straight a few bends Like i did on my 1965 3/4 ton Had them done buy a guy and did a wonderful job
Re: brake line kits
I ordered a stainless set from www.inlinetube.com for my 1 ton truck. They seem to be spot on.
They were almost 200$ but $$ well spent in my opinion. Posted via Mobile Device
Check out my 70 GMC tow truck project here.......http://67-72chevytrucks.com/vboard/s...d.php?t=440431 Member of the 1-Ton Club! http://www.eastcoastcarandtruck.org |
Re: brake line kits
mbgmike if i udnerstand,you have front brake lin kit for $50.00 is it for front disc brakes
Re: brake line kits
Not sure this is legal. I think the poster needs to subscribe
