Old 05-17-2011, 06:19 PM   #1
steve'62
steve'62's Avatar
drip rail question
I was wondering what the best caulking is to use on the drip rail. What have you guys used, and what works best as far as sealing out water?
steve'62 is offline   Reply With Quote
Old 05-17-2011, 06:41 PM   #2
noxided
Re: drip rail question
I have actually used jb weld once. There was some rust through, and i couldn't get in it to weld and grind so i cleaned it out and put some jb weld on with my finger. When it was painted you couldn't tell.
noxided is offline   Reply With Quote
Old 05-17-2011, 06:57 PM   #3
markeb01
Senior Enthusiast
markeb01's Avatar
I use JB Weld for everything so I’m a firm believer in that approach, if it’s what you need. Post #3 on this thread shows how I did my rain gutters:
http://67-72chevytrucks.com/vboard/s...ht=seam+sealer
Evercoat Maxim self-leveling sealer. The nice part is it can be applied with a standard caulking gun
Old 05-18-2011, 10:25 AM   #4
rbar
rbar's Avatar
The local body shop uses some brand of seam sealer.
1963 Chevy stepside 327
1965 Chevy swb 383
1996 Mystic Mustang Cobra
2009 Pontiac G8 GXP 415hp/415tq 6speed
rbar is offline   Reply With Quote
Old 05-18-2011, 10:27 AM   #5
64fleetside
I used 3M self-leveling seam sealer
64fleetside is offline   Reply With Quote
Old 05-18-2011, 11:17 AM   #6
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Are you guys actually filling in the drip rail or just sealing it?
Did these ever have a drain hole somewhere in it? Mine doesnt.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 05-18-2011, 11:24 AM   #7
hardhead
My 66 has four small slots for draines. Two on each side. One at the rear and one towards the front right before it curves around to the windshield.
hardhead is offline   Reply With Quote
Old 05-18-2011, 11:42 AM   #8
Rogue
Airport Bum
1964 Chevrolet C-10
1941 Chevrolet coupe
1962 Thunderbird
1959 Edsel Villager
1963 Skylark
Rogue is offline   Reply With Quote
Old 05-18-2011, 12:03 PM   #9
61_FL_Apache
Who Me?
I thought I remembered seeing them on my 65, but they are filled on my 61.
Steve
2001 Blazer 4D 2WD
Old 05-18-2011, 12:09 PM   #10
chevyrestoguy
chevyrestoguy's Avatar
Yep. That's exactly what it's designed for.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-18-2011, 01:48 PM   #11
64fleetside
I whittled a paint stick to put into the drain holes, then removed them after the seam sealer set up to keep the drain holes open. Worked fine.
Old 05-18-2011, 02:39 PM   #12
theastronaut
theastronaut's Avatar
I used Fusor Self Leveling seam sealer on my '65 resto project. Its an epoxy so no shrinking and cracking later on. Its sandable if you need to touch up a spot. Let it cure, scuff the sealer with a grey 3M pad, and shoot your paint on top.
theastronaut is offline   Reply With Quote
Old 05-19-2011, 12:11 AM   #13
Captainfab
60-66 Nut
What does the gun cost for that cartridge? The 3M guns are around $100.....
Old 05-19-2011, 09:08 AM   #14
theastronaut
I'm not sure on the cost of the gun. My dad owns a glass shop and a sales rep gave him a pnuematic dual-mix gun like the one in this vid:
Old 05-19-2011, 09:39 AM   #15
jbgroby
jbgroby's Avatar
There were two factory pinch holes toward the back of the rail, where it tend to angle upward. I had the guys close mine and the painted ran seam sealer all arouns the bottom where the roof panel meets the top of the cab. Since th etruck will be 90% show and 10% crisue she probaly won't see much rain. LIke many, I'll keep a few towels and pat her down before and after the rain.
jbgroby is offline   Reply With Quote
Old 05-19-2011, 12:23 PM   #16
theastronaut
I did a google search, a SEM brand dual mix applicatioin gun cost around $60 bucks. The pnuematic guns run around $300.
SEM gun:
http://www.autobodytoolmart.com/sem-...9-p-15587.aspx
Pnuematic:
http://www.autobodytoolmart.com/sem-...9-p-15586.aspx
To keep the drains open, I rolled up wax paper into a cone shape and slid that into the drain holes before I applied the seam sealer, then took the wax paper out once it had cured.
Old 05-19-2011, 06:50 PM   #17
steve'62
steve'62's Avatar
Anybody have pics of the drains after sealed?
Old 05-19-2011, 10:26 PM   #18
dracko
dracko's Avatar
I also used the 3M self leveling seal sealer. THe paint supply place lent me the double barrell caulking gun for a $40 refundable deposit. Call around, no reason a place can't lend it to you for a few days.
dracko is offline   Reply With Quote
Old 05-19-2011, 10:34 PM   #19
steve'62
steve'62's Avatar
I have a couple at work I think I could borrow it for the weekend as long as I bring it back!
Old 05-20-2011, 12:17 AM   #20
Captainfab
60-66 Nut
So the SEM gun will work with the Fusor cartridges? The SEM gun says it is for 7oz cartridges, and the Fusor cartridges I find online are 10.1oz.
SEM gun:
Pnuematic:
Old 05-20-2011, 09:08 AM   #21
64fleetside
With a MIG welder & some time a regular cheap caulking gun can be converted to pump most all of these seam sealers-most are proprietary-you must use this gun w/this brand sealer-but if you're poor(like me) & cannot borrow one, it can be done fairly easily.
Most guys cut off the end of the caulk gun & weld on a double barrel setup, sized to the sealer tubes-I've seen old 3/8 drive sockets used, flat washers, you name it
Old 05-20-2011, 10:35 AM   #22
theastronaut
I just checked the pneumatic gun we have at the shop, and its a Cox brand. It know it works with fusor cartridges but at the moment I don't have any SEM cartridges to check and see if they'll work. I think the difference in the SEM and Fusor tubes are the length?
