Old 03-24-2002, 11:59 AM   #1
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Talking Help for a fellow member
Hey, gang I'm from the 73-87 truck forum. I received the following message from a board member. I can only answer a few questions because I'm more familiar with the 73-87 trucks. The 67-72 trucks are just a little different. Can y'all help me answer his questions? You can guys can do a better job and I can. Thanks
Hello,
I was reading some of your posts on the chevy board about 700R transmissions. When I looked at your profile and saw that you lived in TX I had to ask you a couple of questions (HEHEHE!!) about installing one of these transmissions in my truck. I have a 70 Chevy SWB truck with a 250 six and 3 on the column. I am going to put a 327 motor in it. My questions are as follows:
1. I have a truck tilt auto column and how do you know what gear you are in (Except by feel) and will it work with a 700R?
2. Will I have to move the trans mount and will a standard auto trans mount from 67-72 work?
3. Will the drive shaft have to be shortend/legthened.
4. Will a T350 yoke work with it.
5. Have you heard of a hydraulic kit to lock up the converter and know if this is a good idea.
6. I have heard that Lokar makes a good cable and accessories for these transmissions. What did you need to buy to get the linkage and everything to work.
7. Who rebuilt your transmission so I can get them to do mine. I have heard that some year models of this transmission are sturdier. Which year should I look for.
I know this is a lot to ask so you don't really have to respond but I am at the very beginning of my quest to get decent gas mileage out of the truck. Any additional info or suggestions you could give me would be greatly appreciated.
Thanks,
smonty
Gerardo
1983 Custom Truck
TX Plates: "BAD BOW"
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
