Old 05-17-2011, 08:16 PM   #1
karlbenz
trans. ?
will a t5 trans hold up in my 64 1/2ton?. stock 350. no playing around just driving. I do occasionally pull loaded trailers
thanks
karlbenz is offline   Reply With Quote
Old 05-17-2011, 08:50 PM   #2
Stubnosebrock
Re: trans. ?
It may last if your real easy on it. But thats a big maybe. I have heard of people grenading them behind 305's.
Stubnosebrock is offline   Reply With Quote
Old 05-18-2011, 12:40 AM   #3
Captainfab
60-66 Nut
Re: trans. ?
If you use your truck as a truck sometimes, a car 4 speed won't be the best choice. The T5 isn't rated at the amount of torque a typical 350 will put out.
Old 05-18-2011, 06:29 AM   #4
karlbenz
Re: trans. ?
guess i"ll stick with the 4l60 for now then.
Old 05-18-2011, 07:59 AM   #5
Scot_Douglas
Scot_Douglas's Avatar
Re: trans. ?
I guess it would come down to how heavy you load it when you're hauling and which T5 you choose. A "world class" T5 with a pre-88 S-10 tailshaft housing would be the strongest option (w/o opening up the insides) while keeping a decent shift lever locations.
I'm giving a weaker, "non world-class" transmission a try in my truck (mild 350) to see if lasts. Not on the road yet, so I have no personal data in a C-10.
I do know that the world-class transmissions they put in the old mustangs were pretty tough. I know the 302 had less HP & torque of a SBC AND I know that the fox-bodied Mustangs were 3000 lb with a driver, HOWEVER:
I have an uncle that used to race a 89 5.0L LX Mustang. He had just about every bolt-on go-fast goodie (3.73:1 rear end, off-road exhaust, different rocker arms, computer chip, underdrive pulleys, cold air intake, etc) and consistently ran low, low 13 second quarters. His goal was to break into the twelves without major engine mods.
He got these 1/4 mile times with the aid of 10" drag slicks and dropping the clutch at redline when he launched.
Now, I know that first gear launching is a different usage than towing a load in 4th or 5th gear, but I am confident I won't break my trans by just "spirited" driving.
1964 C10 - sold to chris1044
1966 C10
Build 'Fread
Scot_Douglas is offline   Reply With Quote
Old 05-18-2011, 08:31 AM   #6
lakeroadster
Re: trans. ?
thanks
Yes it will hold up to a stock 350 if you select the right T-5 tranny.
There is a ton of data here regarding 5-speed compatibility and strength. Click on this link The T-5 Thread
lakeroadster is offline   Reply With Quote
Old 05-18-2011, 12:21 PM   #7
chevyrestoguy
chevyrestoguy's Avatar
Re: trans. ?
You currently have a 4L60, or are you looking for a few extra gears for fuel mileage?
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 05-18-2011, 05:22 PM   #8
karlbenz
Re: trans. ?
I have a 4l60. just never cared much for an auto in a truck
