Grandpa in the rustmobile...
Headlight relays need help with them
Im about 1/2 way done. It wont be clean but the next one I'll do will be now that I know how.
Do I run 2 wires from the battery to the relays? or can I tie the 2 post on the relay together, then put 1 inline fuse before the battery? Do I have to use 2 fuses? And is 85 on both relays ground? 1 Read the artical 2 Parts list 2 bosch relays, spade connecters, wire, and inline fuse. 3 Look at wiring sheet 4 Decide that you can do this 5 Start by finding the 14LG and the 18LT wire on the back of the left headlamp. 6 Disconnect the (-Neg) battery cable. Mount the relays to the core support above the horn. You may have to make room for them. 7 Follow the 14LG wire towards the fuseblock. Mark it. This is the one to cut. 8 Follow the 18LT wire towards the fuseblock. Mark it 1st. Cut this one also. 9 Do the wiring: cut 18LT (or low beam) and run the wire from the fuseblock to Terminal 86 on the relay. run the other end and that comes from the headlamp plug to Terminal 87 on the relay. cut 14LG (or hi beam) and run the wire from the fuse block to the Terminal 86 on the 2nd relay. run the other end to Terminal 87 of the 2nd relay. 10 Terminal 85 goes to ground. 11 Run a heavy wire (12ga.) from + Battery Post to Terminal 30 of both relays. Just run it through the stock wiring across the radiator. Add a inline fuse on this one. 12 make sure every thing is connected, secure wires, replace (- battery cable ) 13 Enjoy Brighter Head Lights ^Thats what Im going by. __________________
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Headlight relays need help with them
Run a separate fused wire to each relay. You don't want a failed fuse to take out both your high beam and low beam.
And yes, 85 is ground on each relay. This may help:
Did everyone make the cut just after the wire gutter across radiator? Or did you cut just in front of the inner driver side fender?
Im ready to go, I just wanna know where I should 'snip' at. Ive already snipped at the front of the inner fender, but could I snip above the horn and get same results but cleaner look?
I would love to do these mod but it sounds confusing to me!!
![]() I think I will probably take the easy way out and just buy the set up from LMC. Good luck though oldblue1968chevy! Keith |
I got it.
Its really not hard at all, the directions are just confusing as heck!!! You need a roll of black 14 guage, red 10 guage misc electrical connectors shrink wrap etc etc Took me around 4 hours but im slow as heck, didnt know what I was doing etc etc etc Its quite quite easy and the lights are WAY brighter, I just gotta get em adjusted!! Cleaning up the wirnig tomorow! This goes down with disc brakes and swaybar for the front!
You can pull your power off the horn relay. I like it better then a bunch of wires going to the battery and the horn relay buss bar should be pretty close to 14V all the time. In my 72 I ran an 8 ga. wire up to the radiator support to an insulated terminal block that I used to power the relays. I like to use fusible link as well in all the power circuits but fuses work too.
Larry 1972 Chevy C20 Custom Camper 1968 Chevy Camaro RS 1980 GMC K5 Sierra Classic |
#8 | |
I didn't snip any wires. I simply slid them out of the back of the factory connectors by depressing the little ears with a small, flat blade screwdriver. This is a great mod. oldblue1968chevy won't be replacing his headlight switch ever again and his night vision from the cab of his truck just improved. All for about $15 in parts.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
Junior Member
I am running a whole new headlight wiring setup with relay kits I got from O'Rielly's. I am using new plug connectors for the headlights. Also since this is on a vehicle that has the dimmer switch in the column I am using an on-off-on toggle switch mounted in the dash.
The whold process is a little tricky, but I am taking my time and everything seems to be working out ok. This is practice for the relay set up I hope to do on one fo my project 67-72 trucks in the future, probably the '67.
'67 Chevy C-20 short stepper - build complete, 454/SM-465. '75 C-30 Single Cab DRW-350 small block/NP-435. '77 GMC-6500 Dump Truck, 427 Tall Deck. '92 GMC K-3500 Duallie, 454/4L80E. |
Hey Guys, sorry to mention this, but I feel it is important. The whole idea is to get full voltage/amperage to the headlights, but the replacement sockets and the original ones, too, are 16ga! This is WAY to light to do the job we want to do. I used the original type
16ga from the switch to my relay bank as kickers, then I ran 12ga all the way from the relays to the the headlights! I took the sockets apart and replaced the 16ga pigtails with the 12ga runs. My relays are mounted on the passengers fender so the battery runs are really short at 18" and 4 1/2'. I have 14.2v or battery voltage at the lights! I know it's fussy and takes more time, but it is worth it, especially if you run Halogen or HID lights, and it keeps the sockets from getting so hot! Best wishes, Les |
dazed and confused
Saved future job
members met: redbaron69, billsbowtie,nc67 |
Thanks roadmarks!
Yall think i'll be okay as is, (not planning on going HID or anything)..
#13 |
Old member
I ran one wire to both relays. Never had a issue yet 4 years running. The relay cares all the load and then the head light switch has hardly anything on it. I guess running bigger wire to the lights is OK but I don't know if it's worth it unless you do go to HID's.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#14 |
Recalculating.....
subscribed
Brian - (BBrendal) 1969 Chevy Camaro Z28 1972 Chevy Blazer CST 2004 GMC Yukon (The truck that pulls the car trailer) 1972 Chevy Blazer CST #2 (Finished and sold!) Blazer build link... http://s1213.photobucket.com/albums/...rendal/Blazer/ |
#15 |
18ga doesn't belong on a motor vehicle unless it runs on 4 Double As! 16ga is as light as I go. I melted a headlight socket once so now I don't take any chances. If you agree with what I said and can use the information, great! If you disagree, also great! That's why I enjoy these forums.
best to all, Les |
#16 |
Ive gotta ?
I have a 16 guage wire going from alt to my (+) battery. Thats not big enough, is it?........
#17 |
I don't think so, and neither did the factory. I believe you should make it 12ga and solder all the connections. Crimp-ons and Scotch Loks are just places for corrosion to start. Corrosion = voltage drop and resistance. Use heat shrink tubing on the joints and you almost can't go wrong! Good luck!
Les |
#18 |
![]() Join Date: Oct 2007
subscibed for future use..thx all for your input ..
When you learn a thing a day you store up smart. |
#19 |
Deceided to dust this off...^^^
EDIT!!! Whoops, dusted off the wrong one!
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
#20 |
Bump
63 big window lwb bagged and shaved |
#21 |
This thread should be a sticky! Good reference info.
#22 |
Msgt USAF Ret
![]() ![]() Join Date: Jan 2005
It's in the electrical forum in the the electrical FAQS thread.
........ http://67-72chevytrucks.com/vboard/s...d.php?t=188478
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
