Old 05-17-2011, 08:51 PM   #1
slimneverdies
slimneverdies's Avatar
Sway bar question
Are the 1988+ 1/2 ton 1500's sway bars similar to the 73-87 c10's? I was at the junkyard all day and I noticed like 10 of the 1500's and they all had sway bars with end link style connections. No C10's in sight. If they can be used will it also work if my truck is bagged? One more thing, I read somewhere that if I'm using a dropmember that the stock bars will need to be bent inward an 1" on each side...
Slim
Long live SLIM
At least try to buy American
slimneverdies is offline   Reply With Quote
Old 05-17-2011, 10:29 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Sway bar question
Buy your sway bars from Porterbuilt.
They sell stock width and the Dropmember version also.
Great products.
I have one of each.
Keith
Convert to disc brakes.
Old 05-17-2011, 11:47 PM   #3
lilpoindexter
lilpoindexter's Avatar
The 88+ run their sway bars differently than the 73-87.
just be patient, and look for a big ass 8 lug suburban, and then take the wrist thick sway bar off that bad boy. I got a 1.25" bar off a suburban for mine.
lilpoindexter is offline   Reply With Quote
Old 05-17-2011, 11:52 PM   #4
slimneverdies
I actually did see a 4x4 suburban but I thought it was totally different.
Long live SLIM
Old 05-18-2011, 12:00 AM   #5
slimneverdies
Great products.
I have one of each.
I would love to. After buying a dropmember and all these other components it's time for me to put some of my own fab skills to work and save some dough....
they only want $15-20 for them at the yard
Long live SLIM
Old 05-18-2011, 07:45 AM   #6
lolife99
lolife99's Avatar
The Dropmember bar needs to be narrower.
Keith
Old 05-18-2011, 01:16 PM   #7
slimneverdies
Yeah Keith, I hear it's like 1" on each end. I probably could take it to a machine shop and have them bend it for a few bucks.
Long live SLIM
Old 06-07-2011, 10:27 PM   #8
slimneverdies
Ok guys, I finally got my sway bar and what a good deal it was. I know you guys say that the dropmember needs a narrower bar but here is what I have. Its a 1-1/8'' bar with end links. I can make the brackets to mount it, I just need to know is this the right spacing. The arms are CPP arms and I have deleted all of the brackets so I can fabricate my own. It looks pretty straight foward but I need some opinions before I start.
Long live SLIM
Old 06-07-2011, 11:00 PM   #9
texastrendz
i think you are going to have to wait and mock it up on the frame. it will be a lot easier that way. I bought nates sway bar and used factory arms from 73-87 on a 72 truck equipped with a dropmember. the end links you can get at autozone made by energy suspension. the ones that came with my sway bar were junk. set it up at ride height and keep it in plane with the floor. that is what i did and it turned out nice. make sure you turn the wheels lock to lock to check for clearance before you burn it all the way in. good luck. oh, i used the shortest link set they offered. i think it was 1 3/4" spacer in the middle.
texastrendz is offline   Reply With Quote
Old 06-08-2011, 10:34 AM   #10
SCOTI
SCOTI's Avatar
The shorter the 'link' the quicker the reaction when force is applied. I like to buy the longer links & cut them to size. Then just get the 'correct' length bolt as needed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-08-2011, 01:55 PM   #11
slimneverdies
Ok, thanks. I'm waiting on some bushings from Nate before I install so I guess that part will have to wait. I asked around at a few shops and nobody around here will bend it. I guess this is not a common practice....
Long live SLIM
Old 06-08-2011, 03:26 PM   #12
texastrendz
I know it is not common practice, we did heat and bend my sway bar on my dually project. It seems to be fine. I have put several thousand miles on it with no issue. Heating it towards the ends is where we did it.
