Old 05-17-2011, 09:07 PM   #1
mightymouse
mightymouse's Avatar
Talking blazer buckets question?
I'm looking for buckets for my 72 p/up. and found some for blazer and was wondering are they the same except for the hard plastic on back? are they same height? will lever on back of passenger clear cab? thanks for any info..mm
mightymouse is offline   Reply With Quote
Old 05-17-2011, 09:40 PM   #2
too much stuff
Roadtrip!
too much stuff's Avatar
Re: blazer buckets question?
They are the same. Only real difference is the pass mounts. You can buy the pass side mounts repo now. Drivers side is the same.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 05-17-2011, 09:41 PM   #3
67/72junkie
if they are from a 69/72 blazer they are the same except passenger mount.You can buy truck mount after market from several vendors.73 up blazer seats will work but have slight differences in the foam and lower skirts. 69/70 71/72 have different seat bunn and use different covers.
67/72junkie is offline   Reply With Quote
Old 05-17-2011, 09:50 PM   #4
mightymouse
thanks for info to much stuff . i guess ill not bid. they need foam +covers and now brkts to convert to p/up i guess... there on ebay if anyone interested. thanks again. mm
Old 05-17-2011, 10:48 PM   #5
67/72junkie
The ones one ebay are from a 73 or 74.
Old 05-17-2011, 11:13 PM   #6
mightymouse
are you sure it says 72? i changed my mind and made a bid.. i hope its a 72..thanks ...johnny
Old 05-17-2011, 11:28 PM   #7
too much stuff
Roadtrip!
Do you have an item number?
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 05-18-2011, 12:58 AM   #8
NW_Ryker
The passenger mounts on a blazer are different from those of the trucks. They are set up so the seat flips up allowing access to the back.
NW_Ryker is offline   Reply With Quote
Old 05-18-2011, 05:46 AM   #9
cdowns
cdowns's Avatar
i used blazer buckets in my truck with the blazer mounts with very slight mods// the flip foward was great to help in stashing stuff behind the seats for good additional storage space
Old 05-18-2011, 08:06 AM   #10
67/72junkie
The listing says they will work for a 67/72 but never says they are 72.I have 13 sets of 69/72 buckets in my attic and several more 73/77 I know the differences in all years.The ones on ebay are from a 73/74 blazer the mounts are taller than 72 and the rear of the lower skirt runs up at and angle shorter by 1 1/2" than 69/72. 72 covers can be put on these but the lower cover need part of lower unstitched and resewn to fit correctly.I can post you pic of how to make the mod if needed.I would not buy these on ebay unless very cheap.new foam is not cheap and it will cost to rework lower covers to fit correct.
Old 05-18-2011, 02:37 PM   #11
VA72C10
VA72C10
VA72C10's Avatar
is this the auction?
http://cgi.ebay.com/ebaymotors/ws/eB...SS:MOTORS:1123
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-18-2011, 05:52 PM   #12
67/72junkie
look at the mounts and the side view of the skirts and if you know the years you can tell what they are.
Old 05-18-2011, 06:02 PM   #13
mightymouse
yes thats them . i thought they were 72.thanks for all info everybody. well i hope some one else wants them ha-ha thanks..j.w
Old 05-18-2011, 06:28 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
yep, the mounts are the dead giveaway...although having the covers off makes the skirt difference easy to see on these also...
