Old 05-18-2011, 11:13 AM   #1
veinbar
veinbar's Avatar
How do I mount my spare under the bed?
I have my spare tire in the bed of my truck. Like many of you, I use my bed a lot, so I find myself removing the spare often. How do I mount it under my bed? Is there a spare tire mounting kit, or should I rig something?
veinbar is offline   Reply With Quote
Old 05-18-2011, 01:25 PM   #2
Rons86
Rons86's Avatar
Re: How do I mount my spare under the bed?
The spare mounting for these trucks always seem pretty clunky to me. I have wanted to try and mount a 88-98 truck spare tire carrier with the cable. LMC carries the original carrier, but it is expensive.
Rons86 is offline   Reply With Quote
Old 05-18-2011, 01:26 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
there is a kit.. i used tome nuts and three quarter rod after finding a salvage spare tire carrier in the boneyard.. ill try to take pics later for you
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-18-2011, 08:42 PM   #4
Brian76GMC
Brian76GMC's Avatar
My truck has no spare mount either. I may look into adpating a later model cable mount deal. Thanks for the suggestion!
79 Chevy Big 10
350/T350
My GMC's that I sold
Brian76GMC is offline   Reply With Quote
Old 05-18-2011, 09:00 PM   #5
chrismoore701
chrismoore701's Avatar
I found the cable style I plan to mount to the bottom of my truck, go to the bone yard and pull one out, it should work
Chris
_______________________________
1979 Chevy Stepside SPORT
2018 Chevy Silverado, 39 years apart
My build 2008-2016. http://m.imgur.com/a/bURrE
chrismoore701 is offline   Reply With Quote
Old 05-18-2011, 09:43 PM   #6
my4by2
my4by2's Avatar
The shop building my truck removed the original swing-out spare tire mount (optional equipment) from my truck & it's not going back on since mine will be on a custom mount in the bed. Give them a call & I am sure they'd be happy to sell it to you for cheap... It's WFO Concepts in Auburn, CA. (530)268-9494 - ask for Trevor. Hope it helps!
1977 Chevrolet K30 LWB Crew Cab
497HP Mast Motorsports 6.0L LY6 HO engine
GM NV4500 5-speed, Centerforce clutch + NP205
D60 + 14-bolt FF w/ Eaton posi + disc brakes
Skyjacker 2.5" full spring lift w/ Nitro shocks
Custom paint + interior
http://67-72chevytrucks.com/vboard/s...d.php?t=435722
my4by2 is offline   Reply With Quote
Old 05-19-2011, 12:10 AM   #7
rayfinseats
LMC has ones that bolt the tire to the side of the (inside) bed. I had a rear cable model rust out and drop my spare last winter (1990 1500). I may try to fabricate one for my 83 K10.
rayfinseats is offline   Reply With Quote
Old 05-19-2011, 03:57 PM   #8
veinbar
veinbar's Avatar
What is superior about the later style mount?
If I mount my spare tire under the bed, will I still have the option of adding a 2" receiver hitch?
Old 05-19-2011, 03:59 PM   #9
veinbar
veinbar's Avatar
I will try to look up this mount type. I just need to see its' functionality. Thank you for the offer and I'll get back to you ASAP.
Old 05-19-2011, 04:20 PM   #10
tucsonjwt
Many stock under mount spare tire assemblies have been removed in order to accommodate a frame mounted receiver hitch. This is why a lot of old trucks don't have a spare tire carrier. It is also hard to find the under mount hardware because people tend to throw them away. I spent the money to re-install the stock hardware and still kept my frame mounted receiver hitch by moving the long pivot bolt about 1 inch forward so the tire would just clear the hitch. Check under your truck to see if you still have the main upper cross member for the spare tire. You can then buy the rest of the hardware from LMC, or get the whole works from them if you need to. I did this and the parts were OK (all made in Taiwan). I would try to get the OEM GM part numbers and search for those parts on the net if I had to buy the parts again - maybe at Vintage Parts.
The cable set up would be better if you could get it to work. The advantage is that you don't have to muscle the tire under the truck to work it on to the carrier to remove and replace it. You would have to find a way to drill a hole in your bumper for the crank handle to engage the cable mechanism. I have a dump hoist conversion, so my bumper moves with the box when it goes up and down, so the cable system would not work for me without some cobbled up mod.
Here is a pic of the top cross member you need for a stock set up.
tucsonjwt is offline   Reply With Quote
Old 05-19-2011, 07:16 PM   #11
1LowToy
Here's mine. I hate it. I'm going to look for something else. My old chevy Luv and Nissin are all over this one.
I just hope I can find the plate to my floor jack before I need to put the spare on
1LowToy is offline   Reply With Quote
