05-18-2011, 02:02 PM | #1 |
Welding a step notch on a 68 1/2 ton frame???
So i have 68 GMC frame that i am welding a step notch to. My question is, right were the notch needs to be welded the frame curves in on both sides. I want my notch to be straight and seems difficult with the frame as is. I hope some of you guys know what im talking about. Any advice on the topic would be greatly appreciated. Thanks
05-18-2011, 02:30 PM | #2 |
Re: Welding a step notch on a 68 1/2 ton frame???
The pre-bent weld in kits are the best way to go by far. They match the curve of the frame.
New Project: 1966 LWB C20 Plans: 1/2 ton conversion Dropmember front Dropmember rear Corvette discs Restored raised bed http://67-72chevytrucks.com/vboard/s....php?p=4295210 |
05-18-2011, 04:14 PM | #3 |
Yeah, I would recommend a pre-bent kit. I just welded one in last weekend, one from S/d and it worked out pretty good.
----------------------------------------- My 67 c10 Thread. http://67-72chevytrucks.com/vboard/s...d.php?t=409192 |
05-19-2011, 11:04 AM | #4 |
so i looked all over sd and cant find the pre bent notch. i already have the one they offer for 67-72 but its not pre bent for the frame. help???
05-19-2011, 12:14 PM | #5 |
Porterbuilt Streetrods, is the place you need to buy the notch from. He is a vendor on here and will give great advice and service of his products. You can buy it in pieces, tacked together, or even fully welded from him.
05-19-2011, 01:24 PM | #6 |
http://*******************/notches/63...tch-sold-pairs
This is the notch I used, it follows the curve in the frame just fine. But as for Porterbuilt, I kind of wished I would of gone with them. Better service and from what I've heard, better product. I had to grind down parts of the sides of my frame to get the notch to seat right. Nate is a real good guy. I would hit him up man, he can help you out. http://67-72chevytrucks.com/vboard/member.php?u=10160
05-20-2011, 08:47 PM | #7 |
Hey thanks for the advice guys.
05-20-2011, 09:40 PM | #8 |
low n' slo
got mine from porterbuilt, fits like a glove!
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
