Old 05-18-2011, 09:29 PM   #1
ybnaford
Junior Member
ybnaford's Avatar
MultiFunction Turn Signal Arm/Switch
Today I replaced my Mulitfunction Switch/Arm on my 04 Silverado. I looked at a few places online comparing prices on the before mentioned part. They were ranging from $135-$160 for the part. I stumbled upon 1AAuto.com and the part was $79.95 mailed to me USPS. Ordered on Sunday, order processed on monday, shipped, then got to me on Wednesday.
The reason for replacing was, all of a sudden my wipers while on intermitten, would just go on continiously and not shut off. After researching this issue I found it to be a problem with this particular part.
I looked for videos on line, with none to be found, so I just jumped right in.
I removed the instrument/dash bezel. Popped very carefully, the steering column covers and found the unit right there on top. I did have to take the lower cover down just a little with out removing the steering column tilt arm, to gain access to the lower torx screw holding the unit from the bottom. There was a single torx screw on top with 4 wiring connections to remove and the unit is in your hand. Reassemble in careful reverse order and you now have a new Mulitfunction Turn Arm/Switch installed. Part works great and the price was right.
04' Silverado 1500 ExtCab, 4x4, SWB - 240,000 & still Going, 62' C10 SWB, Stepside - Ole Green Girl!
ybnaford is offline   Reply With Quote
Old 05-19-2011, 08:31 PM   #2
NateK4340
NateK4340's Avatar
Re: MultiFunction Turn Signal Arm/Switch
Thanks for the great info! Sounds like it was an easy fix. I can't believe you found that part for almost half the price of the others. I'm going to bookmark that website just in case mine goes out.
"Only two defining forces have ever offered to die for you:
1. Jesus Christ. 2. The American Soldier, One died for your soul, the other for your Freedom. "
In the Garage:
'02 Silverado Ext. Cab Z71 5.3l
'70 C20 Longstep 402BB
NateK4340 is offline   Reply With Quote
Old 05-20-2011, 11:14 AM   #3
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
1AA, gmpartsdirect and rock auto are great
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
