05-19-2011, 12:17 AM | #1 |
Starter problems
ok, been trying to see if the motor in my truck is work going thru or not. It was turning over for a while and then the starter started clicking. i took it off and had it tested and it passed. put it back on and its clicking again. any ideas? thanks in advance
05-19-2011, 11:42 AM | #2 |
Re: Starter problems
Insufficient voltage, either due to faulty wiring or a bad battery.
05-19-2011, 11:57 AM | #3 |
Who Me?
Make sure all the starter connections are real clean!!!
I had the same problem in the past.
Steve 1997 Tahoe LT 4D 2WD (DD) 2001 Blazer 4D 2WD 1961 Apache 10 (sold) 1965 C10 Stepper (sold) |
05-19-2011, 12:34 PM | #4 |
Make sure you have a ground strap on your motor..................Had that problem with my 65....................Hemmit
05-20-2011, 10:13 AM | #5 |
Just went throug this earlier this week with my 69 Chevelle...about half the time it would start, about half the time it would just click.
New battery fixed it right up. |
05-20-2011, 10:36 AM | #6 |
1961 crewcab
...and I would go with new battery cables.. they start corroding up at the terminal, and the whole cable will go, so even if you change the terminal, you still might have the problem... you can usually see it when you take the terminal off, there is a green"vein" of corrosion running through the wire..
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
05-20-2011, 11:14 AM | #7 |
ok...so not to steal a thread but i have an issue also that someone might be able to throw some light on....when i hit the ignition switch I can hear the solenoid engage but the engine wont turn over....keeping hitting the ignition and then it will fire...other times it will turn over the engine on the first try....brand new cables brand new (remanufactured) starter.....any ideas?
