Old 05-19-2011, 02:49 AM   #1
dmack91
dmack91's Avatar
Power Steering Noise
OK, my question is on the PS system. It works well, but often times when going around corners, it will let out a shrieking noise. Nothing felt through the wheel, but just a loud screaming noise.
While I like to see people looking at my truck, I don't necessarily like it for this reason.
I have done the standard bleeding (slowly turning lock to lock), both with the engine off and running. I changed the belts, retightened them, and still have the problem.
Any suggestions?
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 05-19-2011, 06:49 AM   #2
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
Re: Power Steering Noise
Most of the time it's the belt but there is a good chance that it's the bearings in the pump
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 05-19-2011, 08:03 PM   #3
nbrfd007
nbrfd007's Avatar
Before you start buying parts, pull out the old fluid, replace with Lucas power steering fluid/treatment. This stuff works wonders!!
nbrfd007 is offline   Reply With Quote
Old 05-19-2011, 10:13 PM   #4
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
Used that on my $150 grand am, worked great!
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-20-2011, 03:16 AM   #5
dmack91
dmack91's Avatar
I did a full fluid flush earlier, but with no improvement (wasn't Lucas though).
Thanks for the ideas.
Old 05-20-2011, 03:33 AM   #6
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
OK I'm taking it its got clean new fluid in the reservoir , was the old fluid burnt and black in color ? ,im thinking its air bubble in the pump ,try bleeding the p/s ,jack up the front tires off the ground ,start the engine let idle and turn the steering wheel stop to stop back and forth ,have someone look in the reservoir to see if foam or air bubbles coming to the top .other than that the pump might be just bad on high pressure side
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-20-2011, 10:51 AM   #7
nbrfd007
nbrfd007's Avatar
The lucas is the key.
Old 05-20-2011, 11:19 AM   #8
72lb4x4
Does it do it sitting still turning the wheel?
I'd guess the belt is loose, or glazed, as already mentioned.
I'm missing how magic fluid will stop belt squeal...
72lb4x4 is offline   Reply With Quote
Old 05-20-2011, 01:09 PM   #9
dmack91
dmack91's Avatar
New fluid, new belts - tight, done the front jacked up/turn wheels several times with no luck. Old fluid wasn't black, just a bit dark.
Have seen lots of tiny bubbles at times, but have done the bleeding many times.
Old 05-20-2011, 02:00 PM   #10
Classic Heartbeat
Project Junkie! Fishing Poor!!
Classic Heartbeat's Avatar
If you see lots of tiny bubbles you need to let them settle out befor adding new fluid and turning your wheels. Once they settle out add more fluid, then with the front wheels off the ground start the truck and run the wheels all the way right and then all the way left then shut the truck down. Check for bubble in the fluid. If there is still bubbles, then once the bubbles settle out, repeat the process. I do not believe this to be your problem though, because you discribe the problem to be a shreak not a whine. Shreaking is the belt slipping on the pullys, whining is low fluid or bubbles in the fluid.
I would pull the belt, and dress the pullies with emory cloth to get them to bite the belt better.
I should ask are you turning the wheel all the way either direction? If so, many times the belt will shreak once you come up against the steering stops. WES
On-line catolog
Classic Heartbeat Pickup Parts
WEHEPP@comcast.net
Call us Toll Free (888) 338-2502
Like Us on Facebook
No appointment necessary.
72 BB Chevy Custom Deluxe / Custom Camper
67 I-6 (Soon to be 5.7 LS1) Panel
68 BB Chevy Short Bed
72 6.0 LQ9 Short Bed Chevy 4X4
Olympia's fastest growing truck parts supplier.
Olympia's home for Wayward Chevys
Classic Heartbeat is offline   Reply With Quote
Old 05-20-2011, 02:27 PM   #11
dmack91
dmack91's Avatar
Thanks WES for the suggestion. I will try dressing the pully next. As far as the screech, it doesn't usually happen when static (stopped), so it is not when the wheel is turned to the stops. Usually when going around a corner.
Thanks again all.
Old 05-20-2011, 03:21 PM   #12
Classic Heartbeat
Another thing to consider is your front end alignment. If your front end is out of alignment the tires will squeel going around corners. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-20-2011, 04:27 PM   #13
bosco200
bosco200's Avatar
My truck does the exact same thing...but its not around corners, its when I turn the wheel all the way to the right or left, or when Ive just started my truck and try turning the wheel.
bosco200 is offline   Reply With Quote
Old 05-20-2011, 05:41 PM   #14
Classic Heartbeat
That sounds like a belt issue. Check to see if the belt is loose, there should only be about 1/4" of movement up and down. If more than that it would need tightening. If it still squeals then try a new belt and dress the pullies while you have it off. WES
Also make sure your belt matches your pullies. I have seen people use too narrow of belts and have the same problems.
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-20-2011, 10:50 PM   #15
PatrickGMC70
PatrickGMC70's Avatar
I thought that PS noise at full lock was normal because the pump doesn't have a bypass.
Here, I found a link...
http://67-72chevytrucks.com/vboard/s...d.php?t=418687
PatrickGMC70 is offline   Reply With Quote
Old 05-21-2011, 12:42 AM   #16
fastwillie 696969
~Rest In Peace~
that pump can be bad and is creating the air bubbles on its own ,
for belts use a soap bar on them if you think its squeals from them,but im sure its from the pump it self ,just my guess without looking at the truck
Old 05-21-2011, 09:30 AM   #17
nbrfd007
nbrfd007's Avatar
You must believe in the magic fluid Grasshopper! With all that he has done, sounds like an internal problem. The Lucas will free up sticky valves and condition inside the system. I have seen it work wonders.
Old 05-21-2011, 10:34 AM   #18
Classic Heartbeat
If the pump is full of fluid, this is not possible. The pump is submerced in fluid and unless the fluid level is low when turning the wheel, there is no way for air to get to it.
Also transmission fluid should not be used as power steering fluid. The additives eat the seals in the steering gear. WES
On-line catolog
WEHEPP@comcast.net
Like Us on Facebook
Old 05-21-2011, 10:45 AM   #19
68gmsee
Active Member
68gmsee's Avatar
re. loud squeeling: I'm with the belts/pulleys crowd on this one.
I'm not talking about the gearbox stop noise. But in all my experiences with the high frequency squeeling while turning it's always been either the belts, belt/pulley alignment or the metal contact surface on the pulleys being glazed or burnt.
In another case I had a Tahoe that had the multi groove pulley that was so worn the new belts would slip on it. I would up having to get a new pulley.
Check the belt alignment carefully. See if you can locate a cheap pump with the pulley at the junkyard to try.
68gmsee is offline   Reply With Quote
Old 05-25-2017, 01:12 PM   #20
toolboxchev
Well thought to add this today due to same issues with growling going on. This would be just after replacing the steering gear with a new re-manfactured Cardone unit.
WES is spot on this, ran through the steering 20 turns, engine off. Burp, added fluid, did again for 20 turns. Then started engine and did the same. Just took it for a test drive and am very happy!
Thanks Wes for your guidance on this, hope to meet you soon!
toolboxchev is offline   Reply With Quote
