Old 05-19-2011, 11:42 AM   #1
parrisc19844x4_468
parrisc19844x4_468's Avatar
Holley850 700R help
Anyone know how I can install mykickdown add-on bracket work with this carb(4150). do I need to change out the carburetor linkage?
2017 Silverado LTZ 6.2
1984 Scottsdale K10 - 468 700r 4x4 lwb
1978 GMC Sierra Grande K15 350 Soond to be 406 th350 4x4 swb
1968 GMC 20 305 V6 good ole wood hauler.
Good Fences make good neighbors
parrisc19844x4_468 is offline   Reply With Quote
Old 05-19-2011, 01:39 PM   #2
jrcaprai
Re: Holley850 700R help
The TV cable on the 700R4 is NOT a kickdown cable. Trying to adjust it like one will lead to rapid failure of your trans. Read this
http://www.tvmadeez.com/article/index.html
jrcaprai is offline   Reply With Quote
Old 05-19-2011, 01:53 PM   #3
dos0711
dos0711's Avatar
What happens if it is NOT connected?
dos0711 is offline   Reply With Quote
Old 05-19-2011, 02:15 PM   #4
sumran
sumran's Avatar
Tranny death, according to everything I have read.
Randy Summers
Never brake in the learning curve!
1984 GMC Sierra project truck http://67-72chevytrucks.com/vboard/s...d.php?t=446737
sumran is offline   Reply With Quote
Old 05-19-2011, 03:05 PM   #5
parrisc19844x4_468
If not connected it will not kick it out of overdrive when going up a hill. Or maybe in better terms, it will NOT KICK down.. thus the name, kick down cable. regardless of the name.
Old 05-19-2011, 03:19 PM   #6
parrisc19844x4_468
Anyway, my question is not what it is called or how it work.. i know all of that, what I need to know is how do I connect it at the carburetor?
Old 05-19-2011, 09:06 PM   #7
lindstromjd
Gentleman Jim owner x2
lindstromjd's Avatar
Wrong.
Not trying to be an a$$ here, but if you think it's a "kick down" and that it only operates the downshift point, then you obviously don't know anything about the 700r4 transmission. The TV cable controls EVERYTHING on the inside of an automatic overdrive transmission. It does not just control the downshift from 4th to 3rd. If it's not set properly, your transmission will burn itself up in less than 1000 miles. Period. If you're not exactly, 100% certain on how this all works, I think you should re-consider using that particular carburetor for your application.
1975 GMC Gentleman Jim #1
-357 / 700r4
1975 GMC Gentleman Jim #2
-350 / TH350
lindstromjd is offline   Reply With Quote
Old 05-19-2011, 09:21 PM   #8
S10Fan
Old Heap Driver
Anyone know how I can install mykickdown add-on bracket work with this carb(4150). do I need to change out the carburetor linkage?]
I used that bracket with my Holley 670 Avenger Series carb. The bracket has worked very well for the last year or so. I can take a picture of my setup over the weekend. I won't have any daylight to work with until Saturday.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 05-19-2011, 10:14 PM   #9
85burb
85burb's Avatar
The bracket in the lower pic is exactly what you need as well as a bracket to hold the accel and tv cables in place. Holley also makes that. I had both of the holley brackets on my 670 street avendger and it worked great. That trans is a good trans when built properly. Just make darn sure that you get the adjustment correct or it will for sure burn trans up in as little as 3 miles. I set mine close and drove it to a reputible shop trans shop and the set it right. Have almost 2 years and over 400 hp going threw mine and no problems as of now.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 05-20-2011, 11:06 AM   #10
parrisc19844x4_468
Ok, I have the bracket in the lower pic already and i have the bracket to hold the 2 cables in place. i just cant figure out how to hook up the bracket in the lower pic. Seems like something is missing on the bottom of the carabutor linkage.
Old 05-20-2011, 07:02 PM   #11
S10Fan
Old Heap Driver
I'll grab a picture when I get home from work.
Bryan
Old 05-20-2011, 08:21 PM   #12
85burb
85burb's Avatar
I see the problem now. Is that your carb in first big pic? It must be very old or something. Cause it is missing a large portion. Look at summit and do a close up view of a new carb. They have a different linkage now. My carb was a 4150 ro 4160. You may not be able to use that carb with your trans or need a kit of some kind. This is what the linkage should look like. This throttle body has exact same linkage as a newer holley should.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-20-2011, 08:55 PM   #13
S10Fan
Old Heap Driver
Yes, your carb is missing the lower section on the throttle lever.
Here's mine..........
Bryan
Old 05-20-2011, 11:19 PM   #14
85burb
85burb's Avatar
Isint the tv cable supposed to be on that rear post?
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-21-2011, 05:10 AM   #15
S10Fan
Old Heap Driver
My transmission guy couldn't get the cable adjusted properly in that position. We drove back to his shop and added a cable stud in place of the lower bolt, worked perfectly.
Bryan
Old 05-21-2011, 11:51 AM   #16
85burb
85burb's Avatar
Ineresting... Glad it is working out for you. That is the only down side to these transmissions the stupid tv cable. If it were not for them these things would be a lot better.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 05-21-2011, 06:32 PM   #17
S10Fan
Old Heap Driver
Good info on 700R TV cable adjustment.............
http://www.tciauto.com/Products/Inst...ble_adjust.htm
Bryan
holley 700r
