Old 05-19-2011, 12:26 PM   #1
PLANETGETLOW
Pinion Angle
If your truck is lowered or bagged, what angle do you run your pinion angle at?
Any pics?
PLANETGETLOW is offline   Reply With Quote
Old 05-19-2011, 12:42 PM   #2
Dunenutt
Newbee
Dunenutt's Avatar
Re: Pinion Angle
Same angle as the trans output at ride height.
Dunenutt is offline   Reply With Quote
Old 05-19-2011, 12:50 PM   #3
PLANETGETLOW
Re: Pinion Angle
So you're saying parallel to the ground then? The trans output is straight out the back (obviously)
Old 05-19-2011, 02:13 PM   #4
leftcoast66
leftcoast66's Avatar
Re: Pinion Angle
It may be straight out the back, but usually its down a degree, or up a degree from parralel to the ground. That's the angle you're going to put the pinion at.
leftcoast66 is offline   Reply With Quote
Old 05-19-2011, 02:18 PM   #5
Dunenutt
Newbee
Dunenutt's Avatar
Re: Pinion Angle
What he said!^^^ Put an angle finder on the end of the trans yoke, then match that angle on the pinion yoke.
