Old 05-19-2011, 12:57 PM   #1
Tim R
Help lots of body roll best way to stop it
My truck has drop spindles and lowering spings in front factory control arms the rear has 5 inch drop springs and 2 inch blocks . 20 inch coy wheels low profile tires lowering shocks from ccp . Is there a good sway bar set up for these trucks ? The drop is a 5 7 and everything on the front end is new and I used energy suspension bushings in the rear trailing arms .
I just dont know who has the best sway bar parts
Thanks Tim
Tim R is offline   Reply With Quote
Old 05-19-2011, 01:05 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: Help lots of body roll best way to stop it
I'm using a factory 76 1.25" sway bar. Sitting on the bumpstops helps alot. Moving fuel tank lower and farther back helps. These trucks need sway bars bad.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 05-19-2011, 02:51 PM   #3
dan42
dan42's Avatar
X2 on the sway bars - it made a huge difference in my '67. But they're gonna sway a little. They're not Ferraris, that's for sure.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 05-19-2011, 03:17 PM   #4
ARTISTIC
Along with a total front / rear suspension rebuild I also picked up their CPP front and rear sway bar kit.
http://www.classicperform.com/Store/...ck/6372SBK.htm
Im most of the way through installing the front but expect dramatic improvement over the stock "jello" performance.
ARTISTIC is offline   Reply With Quote
Old 05-19-2011, 04:18 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
agree! Sway bar is a must....start with the front and then if you feel you need more add a rear bar too.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 05-20-2011, 12:34 AM   #6
Tim R
Thanks What about porter built do they make a sway bar for stock control arms ?
Old 05-20-2011, 02:38 AM   #7
Autoblueprint
Autoblueprint's Avatar
I used Hellwig front and rear sway bars and poly cab mounts, new cab ( and core support mounts ) are key to having a tight truck along with having a close ratio P/S gearbox.
Check it out:
http://www.autoblueprint.com/1971_pa...n_PageOne.html
John Harlowe
1971 CHEVROLET C-10 FLEETSIDE LOWERED
Autoblueprint is offline   Reply With Quote
