Old 05-19-2011, 01:55 PM   #1
dougminton
dougminton's Avatar
Carburetor opinions needed
Does anyone have any opinions or experience with edelbrock 800 CFM carburetors?
Good or bad doesn't matter.
The TEAL GMC build thread is HERE
1972 GMC SWB
454 oval ports
TH400
fastest 1/4 mile time so far
13.05 @ 104
If you think you have too much horsepower
you obviously have a traction problem !
dougminton is offline   Reply With Quote
Old 05-19-2011, 01:56 PM   #2
dos0711
dos0711's Avatar
Re: Carburetor opinions needed
Have had good luck with the 600 and 750...
1972 C-10 Cheyenne Super | Short Stepside| 454 ci | TH400 | 4:11 rear
dos0711 is offline   Reply With Quote
Old 05-19-2011, 03:42 PM   #3
dougminton
dougminton's Avatar
Glad to hear good things about the edelbrocks.
Anybody have one they hated?
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 03:46 PM   #4
leddzepp
Moderator
leddzepp's Avatar
I love my 750 also.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-19-2011, 03:59 PM   #5
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
might be kinda big for yea ( don't know what you have) but the Ebroc carbs are out of the box ready to run..well.....
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 05-19-2011, 04:04 PM   #6
Lemield
Lemield's Avatar
I've had good luck with Edelbrock carbs over the years....pretty simple to tune if you need to....most times, they just run great right out of the box.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 05-19-2011, 04:08 PM   #7
dougminton
dougminton's Avatar
Thanks, Glad to hear good things about the edelbrocks. It's got a .030 over 454 that I'm twistin to 7200 so 800 CFM should be about right.
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 04:15 PM   #8
dougminton
dougminton's Avatar
I like that, right out of the box is what I want.
I am soooo tired of my holley
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 04:44 PM   #9
hayhauler71
hayhauler71's Avatar
I have ran a 800 for 4 years now no problems at all
Fuzzy
hayhauler71 is offline   Reply With Quote
Old 05-19-2011, 05:57 PM   #10
dougminton
dougminton's Avatar
thanks, thats what I was hoping to hear.
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 06:19 PM   #11
SactoJim
SactoJim's Avatar
I've got a 800 AVS on mine and no complaints. I got one of the calibration kits as well and have messed with it.......what I really need is a good wideband 02 sensor gauge to really dial it in. Looking at the plugs, it may be a little rich still but since I have a small blower on it (383)....better rich than lean!
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 05-19-2011, 06:50 PM   #12
dougminton
dougminton's Avatar
I think ive decide to get one. plugs are cheaper than pistons for sure.
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 07:29 PM   #13
hjewell2
hjewell2's Avatar
454+30= 460cubic-x-7200 divide by 3456= 958 cfm
hjewell2 is offline   Reply With Quote
Old 05-19-2011, 07:48 PM   #14
dougminton
dougminton's Avatar
Is that accounting for my motor not being at 100% volumetric efficiency?
1972 GMC SWB
454 oval ports
TH400
13.05 @ 104
Old 05-19-2011, 08:00 PM   #15
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
you might check into quickfuel carbs thats what i use great carbs
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 05-19-2011, 09:48 PM   #16
Clutch442
Clutch442's Avatar
I have had nothing but good luck out of Edelbrock carbs. That's all anyone I know uses.
Clutch442 is offline   Reply With Quote
Old 05-19-2011, 09:52 PM   #17
hjewell2
hjewell2's Avatar
Very close to 100% If you are running a free fowing exhaust and a loose converter you will use 850cfm at the 7200 mark. Also depending what your lobe seperation angle is on your cam.
Old 05-19-2011, 10:43 PM   #18
72TealnWhite
72TealnWhite's Avatar
can anyone i.d. this carb?
72TealnWhite is offline   Reply With Quote
Old 05-19-2011, 10:44 PM   #19
72TealnWhite
prob too small sorry, i got more pics .. sorry
