![]() Join Date: Feb 2001
Question: Quad Kick-down install operation
It is my impression that on the 69 and 70 (BB) trucks there were two different ways the 400 Kick down switch worked. The kick-down switch mounts to the carb...one set up used a bracket that hit the plunger when the throttle linkage was pressed. Was there another set up used?
So those who are mechanical knowledgeable about these issues...what were the correct ways this switch operated? Were there two methods of hook up? Anyone have any pictures on the set up? Thanks in advance.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Active Member
![]() Join Date: May 2009
Re: Question: Quad Kick-down install operation
Well there's the gas pedal location but IDK if it's correct for a 69-70.
http://www.67-72chevytrucks.com/vboa...d.php?t=315977 |
#3 | |
ttt
Ok...I am going to have to call WES
Member #1049
From what I have found all 68-70 small blocks and 68 big blocks used the same setup..
69-70 big blocks used a completely different switch and bracket.. while wrecking yard hopping the other day I stumbled across and bought a complete big block setup out of a 70 that has the unique switch and brackets. I will try and remember to bring my camera to the shop tomorrow and get you some pictures Last edited by Livrat; 05-20-2011 at 11:59 PM. |
#7 | |
I think my brackets are missing on my carb...and I will need to buy a set
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-20-2011 at 11:59 PM. |
Member #1049
Here ya go.. obviously its the incorrect carb.. but the switch and brackets are as far as I know the "unique 69/70" BB only setup
member #16
![]() Join Date: Dec 1999
Heres one with I think the correct carb and brackets.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Thanks Livrat and john for the pics. Much appreciated
![]() Now I got to find a set ![]() ![]()
Member #1049
#12 | |
Member #1049
http://www.heartbeatcity.com/store/p...jet--67-68-69/ |
#13 | |
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! Last edited by 70cst; 05-22-2011 at 01:01 AM. |
#14 |
Member #1049
The switch and bracket I pictured all came off of a 70 402 and I am not real attached to them. if you are interested I would certainly entertain selling them..
#15 |
And the price as I am interested...Thanks
#16 |
Solved!!! Thanks Livrat
#17 |
ttt for reference...
