Im not sure how to pull of my door panels i take the screws at the bottum.But at the top pannels stuck do i just yank it i have a 83 silverado.i need to put some mirrors and i have to take them off i also have to mount the chrome decal more better since the holes are all ruined and i have to use some washers or something.Pain in the ass
1982 chevy silverado It's all about original guys original let me say again original.
Gentleman Jim owner x2
![]() Join Date: Oct 2010
Re: how to pull off door panels ?
Mine is a 75, so I don't know how much different they are, but I had to roll my window all the way down, and then lift the bottom part of the panel up, and then push the whole thing towards the outside of the door. There were clips on the top that slid into grooves / holes, and you had to kind of rotate the panel up to get them out.
1975 GMC Gentleman Jim #1 -357 / 700r4 1975 GMC Gentleman Jim #2 -350 / TH350 |
Did you get the screw in the arm rest? If you look down where you put your hand to pull the door closes, there's one or two screws there. One has to be removed to get the panel off.
And as lindstromjd said...there's also some clips along the top. For me, the inner window felt was attached to the door trim panel and the door. Required a putty knife or something to slide in there to pop them off. Whatever you do...when you have it ready to come off, it doesn't take much force at all, so don't force it. If you have the armrest screw out, then you probably just need to finess the clips along the top with the window felt. |
Square
there might be a screw behind the door handle too
Squarebody Syndicate |
#5 | |
Ouch !
| Bookmarks |
