05-19-2011, 10:18 PM | #1 |
Disc Brake Kit Question
Hey everyone, I was wondering if anyone has any information on disc brake kits that use a bracket to use your existing drum spindle to mount chevelle rotors? I ask because I am wondering if I can swap the rotors for c10 rotors. If anyone has an answer that would be greatly appreciated.
05-20-2011, 12:01 AM | #2 |
67-72 parts collector,…
Re: Disc Brake Kit Question
I think the bearing sizes are different.
That's why only a 5x4.75 pattern chevelle rotor and 2nd gen. camaro caliper is needed. Buy a set of "direct fit" disc brake spindles for the 60-62 or 63-66 trucks and bolt them on! Then you can use a truck rotor and caliper. Posted via Mobile Device
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 05-20-2011 at 12:02 AM. |
05-20-2011, 12:07 AM | #3 |
60-66 Nut
Just use a set of '73-'87 truck spindles, rotors and calipers. You will have to change the ball joints, but it is a relatively simple and inexpensive conversion.
05-20-2011, 10:41 AM | #4 |
The lug pattern will be 5X5 when using truck calipers....FYI
05-21-2011, 08:49 AM | #5 |
I have bought a set of drop spindles, but I was just wondering when I was looking at a cpp ad in a magazine. Thanks for the info guy and gals.
