Rollin' Old Skool
V-belt pulley question
hey guys, i bought a set of V-belt pulleys from a member here in your side of the forum...he used this setup on a '70 SBC with short water pump...i'm converting my '66 to power steering & bought this setup to use on my truck...the other day my dad informed me that the crank pulley is not lining up with the others...the truck is back in MS, so i'm not able to take pictures...so, i'm just wondering if everything in the parts picture looks correct? in the meantime, i will try to get more details from my dad
Re: V-belt pulley question
Setup looks good to me, except for the pump bracket.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC Last edited by JimKshortstep4x4; 05-20-2011 at 07:36 AM. Reason: Added wording |
Redefining LowBudget
looks like my stock set up....do you have headers?? that will goof things up...is it only the crank pully?
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#4 | |
Rollin' Old Skool
btw, i didn't use those alternator brackets (no accessory holes in heads)...it's a '66 327 Last edited by likaroc13; 05-20-2011 at 10:59 AM. |
yea I had that issue with the old motor in my truck.....not so much with the caddy engine
