Brake Combination Valve warning switch not connected
The other day I noticed that this switch was not connected. Can anyone tell me why the PO might have it disconnected and if there is a danger in leaving it that way?
1972 C-10 Deluxe 350 V8 - 350TH ------------------------------ We're not the jet set We're the old Chevrolet set |
Redefining LowBudget
Re: Brake Combination Valve warning switch not connected
I would just say pull off the other plug and plug in the stock one if the brake light is on in the dash ( when running) then it maybe a switch that works in the wrong direction...you just need to put one in for our trucks
either way no big deal if you have a brake failure the light will come on about the same time you step on the breaks..??
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
I'll bet it is because the plug is different and he didn't want to cut the harness.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
"the other guy"
the stock plug will not fit the aftermarket switch. cut and paste, it can be done cleanly....i just did it.
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
