Old 05-20-2011, 09:45 AM   #1
cst350
cst350's Avatar
need dual horn pic
I took my stock dual horn set up apart for paint but I dont think they were in the stock place or had the original brackets. Can someone with a stock horn set up take a pic and post it? Mine is a 69 Custom 10...
Thanks again
CST350
cst350 is offline   Reply With Quote
Old 05-20-2011, 10:26 AM   #2
custom1970
Member
custom1970's Avatar
Re: need dual horn pic
Do you have a pic of what you have? If not i can take a pic of my set up tonight. They should bolt up on the left side radiator support. you should see two sets of holes about 8" apart. Original brackets were very basic, had one hole and a tab that goes into a hole on bottom horn and over the edge of rad support on the top one. at least that's how mine was set up.
custom1970 is offline   Reply With Quote
Old 12-09-2011, 01:03 AM   #3
blkcorvair
blkcorvair's Avatar
Anyone find a pic of this? I need the same pic to figure mine out!
Too late I found it here......
http://67-72chevytrucks.com/vboard/s...d.php?t=386930
blkcorvair is offline   Reply With Quote
