Old 05-20-2011, 10:36 AM   #1
MalibuKasey
Artist
MalibuKasey's Avatar
Strange noise from my suspension.....
Just a quick pick your brain question... When I turn right I get like a rubbing squeaky sound from the driver's front. It ONLY happens when turning left.
Ive checked EVERYTHING and its not hitting or rubbing anywhere.... any suggestions?
The truck is dropped 5.5/7 with a disk brake conversion in the front....
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66
MalibuKasey is offline   Reply With Quote
Old 05-20-2011, 10:38 AM   #2
fryer1979
Redneck Hillbilly
fryer1979's Avatar
Re: Strange noise from my suspension.....
Make sure the hub is tight, and check the ball joints. That's my first thought....
fryer1979 is offline   Reply With Quote
Old 12-05-2011, 06:17 PM   #3
MalibuKasey
Artist
I FINALLLLLLY figured it out. My rear track was off... the rear driverside inner tire would rub everytime I had a little body roll.... It actually got so hot it burnt the paint on on the inner wheel well. My buddy noticed the burnt paint....
Old 12-05-2011, 06:28 PM   #4
MisterC
MisterC's Avatar
Grats on the find. Did you install an adjustable panhard bar to remedy that?
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 12-05-2011, 06:29 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Thanks for sharing the answer. It might help the next guy that has a similar problem.
Old 12-06-2011, 09:41 AM   #6
MalibuKasey
Artist
Actually.... I had installed the adjustable panhard bar when I did the rear suspension.... I thought I had it pretty close... but I was wrong. It was a 5 min fix... and now im having to replace the tire.
