![]() Join Date: Mar 2011
control arms
I just finished a complete rebuild of my 66 1/2 ton front suspension. New everything. I went to grease up everything and I can't get any of the top or bottom control shaft bushings to take any grease. I am using a hand pump grease gun. Do I need more pressure to force the grease in or is there some other issue or solution? All alignments of the shafts were done to spec.
Salty Sailor
Re: control arms
did you replace the greese nips? they might be gunked up
86 c-10 Custom Deluxe Savannah, Georgia |
Re: control arms
yeah, all new grease fittings. Everything is new.
Re: control arms
I guess nobody has ever run in to this problem or has any ideas. I'll search for advice somwhere else....thanks
Re: control arms
I have had them hard to pump up with grease. Some times slow to pump but never not take grease.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
needs more $$$
Re: control arms
My S10 did this with the upper ball joints. It took several tries, but they eventually started going in...i went through almost a whole tube of grease and lots of napkins.
1970 2wd Blazer |
