Old 05-20-2011, 07:04 PM   #1
emil77
Where to get alignment done?
Hi guys,
My truck is pulling to the right. I assume I am in need of an alignment, correct? I called a bunch of different alignment shops and none can do it as they don't have the specs. I found this thread http://67-72chevytrucks.com/vboard/s...ad.php?t=50601 which lists some specs. Can I just give those numbers to the shop? I live in zip code of 91042, anybody know a shop around here that can do an alignment?
Thanks,
Emil
1972 Chevy C20
emil77 is offline   Reply With Quote
Old 05-20-2011, 08:52 PM   #2
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Where to get alignment done?
You can check the toe in yourself, If I recall correctly....stand at the front of your truck and find the vertical center line of your tires, you then run a tape measure from that center line on one wheel to the center line of the other, (make a note of that measurement), then do the same from the center line at the back of both tires, and for your toe in to be correct you should end up with the back measuring 1/4 - 3/8 more than the front......for example if you measured 75" at the front you would hope to have 75 1/4 or 75 3/8 at the rear.
A factory service manual will give you all the correct specs.
Someone will hopefully correct me if i'm wrong.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 05-20-2011, 10:38 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
i usually shoot for 1/16 to 1/8... 3/8 is gettin kinda up there.
Old 05-21-2011, 02:35 PM   #4
Wrenchbender Ret
I like to set them at 1 degree pos caster. 1/8-1/4 neg. camber. & 0-1/16 toe in.
My 70 drives as good as anything out there.
Wrenchbender Ret is offline   Reply With Quote
Old 05-21-2011, 02:37 PM   #5
emil77
Nice info, but I still can't find a shop to do the alignment.
Thanks,
Emil
1972 Chevy C20
Old 05-21-2011, 03:06 PM   #6
68 IRON
68 IRON's Avatar
Firstone, Goodyear, Sears, Les Schwab.....they won't do it? Never heard of that. Anyway check tire pressures and bring them up to proper level.
68 IRON is offline   Reply With Quote
Old 05-21-2011, 03:25 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Any good alignment shop should be able to do it. That's news to me too...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-21-2011, 03:37 PM   #8
cdowns
cdowns's Avatar
get out and look at private garages owned and run by old guys
Old 05-21-2011, 03:45 PM   #9
Longhorn Man
ask other local hot rodders where they had there's done.
Old 05-21-2011, 03:46 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Yup. All of the big name places won't do it if it is lowered, I had the same problem. Even if they had the specs, I wouldn't trust them to do it anyways beacuse of their initial reluctance. Any old school guy can do it by sight/test driving it. I took mine to a local shop here in Riverside called Jerl's muffler/brakes. An old dude there named Scotty aligned my 5" dropped front end perfectly for $75. It took him about an hour and a half, and he only needed to add 1 shim to each stud to correct the camber.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 05-21-2011, 03:52 PM   #11
emil77
I finally found a shop in Van Nuys that will do it, going to take her in on Monday.
Thanks,
Emil
1972 Chevy C20
Old 05-21-2011, 03:55 PM   #12
leddzepp
Moderator
leddzepp's Avatar
Good deal. Van Nuys is a lot closer to you than Riverside
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 05-21-2011, 04:42 PM   #13
emil77
Thanks,
Emil
1972 Chevy C20
Old 05-22-2011, 10:19 PM   #14
406 Q-ship
406 Q-ship's Avatar
Good, cause my guy is in Redondo Beach.
Lifes journey is not to arrive at the gate well preserved, it is to slide in sideways all used up and wore out yelling.....God what'a ride!
Where patience fails, force prevails
Stapp's Ironical Paradox "The universal aptitude for ineptitude makes any human accomplishment an incredible miracle."
406 Q-ship is offline   Reply With Quote
