Old 05-20-2011, 10:51 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Overheating?
My new 88 TBI 350 overheats when it idles more than 5-10 minutes. How do I fix it? I DO plan to replace the thermostat in the next week or so, what thermostat should I get?
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 05-21-2011, 09:24 PM   #2
thirdstreettito
Resident of Here
Re: Overheating?
Bump
~Bradley~
Miss having a truck
Old 05-21-2011, 10:20 PM   #3
76stepsidechevy
Re: Overheating?
What kind of fan do you have? I put a stock clutch fan back in my truck that came with a flex fan. found out the hard way that the clutch is shot and it will over heat at idle if its left running for more than 5 or 10 mins. Its fine when driving though so I still haven't got around to replacing the bad clutch.
76stepsidechevy is offline   Reply With Quote
Old 05-21-2011, 10:22 PM   #4
VegasBruce
VegasBruce's Avatar
Re: Overheating?
I'd stick a 160 stat in it, and then try it. Go from there, if your still having problems.
Bruce
73 Stepside, 74 Blazer, 75 1 Ton, 66 Barracuda and a 05 Electraglide DD
http://i56.photobucket.com/albums/g1...Rusti192-1.jpg
VegasBruce is offline   Reply With Quote
Old 05-21-2011, 11:50 PM   #5
thirdstreettito
Resident of Here
Re: Overheating?
Thanks so much guys, It's been so long since I owned something that was restored! :P I forgot how stuff works!
~Bradley~
Miss having a truck
Old 05-22-2011, 10:17 PM   #6
thirdstreettito
Resident of Here
Re: Overheating?
Should I get a Severe Duty Fan clutch? It gets up to 105* here in the summer.
~Bradley~
Miss having a truck
Old 05-22-2011, 10:27 PM   #7
VegasBruce
VegasBruce's Avatar
Re: Overheating?
I would change the stat first, It sounds like it is your main problem. Them see what you need to do for the Summer weather. In Vegas it gets up in the 120's. My solution is, NO thermostat, a flex fan, and change the antifreeze the beginning of every Summer. So far no problems with overheating. I use the t-stat housing with the plunger cut out.
Bruce
Old 05-22-2011, 10:32 PM   #8
thirdstreettito
Resident of Here
Re: Overheating?
I have never changed a thermostat(never needed to). How long would it take? Do I need any special tools? Any gaskets? How involved is it? Is there a good brand? What material? Stainless? Copper/steel? Copper/brass? Steel?
~Bradley~
Miss having a truck
Old 05-22-2011, 10:42 PM   #9
VegasBruce
VegasBruce's Avatar
Re: Overheating?
It easy to change, a ratchet and socket, gasket ant a new stat.Put the new one in boiling water first and make sure it opens. Just watch how the old one comes out and put the new one in the same way.
Bruce
Old 05-22-2011, 10:48 PM   #10
jimbonice
jimbonice's Avatar
Re: Overheating?
You're talking two bolts .... easy peasy
jimbonice is offline   Reply With Quote
Old 05-22-2011, 10:49 PM   #11
thirdstreettito
Resident of Here
Re: Overheating?
Sweet! Will there be any mess?
~Bradley~
Miss having a truck
Old 05-23-2011, 12:20 AM   #12
GmtGmt
Conversion Truck Addicted
GmtGmt's Avatar
Re: Overheating?
easy yes, a mess yes
Thomas
Tonight mine pulled a few cars out of snowbanks, and is sitting in my driveway, icicles on the grille, wheels just white cakes of snow, buried up to the lug nuts in powder, straps and chains wrapped around the bumpers, the outline of the wipers clear in 4 inches of snow on the windshield... A tired warrior of the 1980s in a world of low profile tires, front wheel drive, and plastic bumpers, where people stay in their houses until snowplows move the offending substance from their paths, too helpless to travel without AAA and chains and salt, clearing their windows with longhandled brushes while gently stepping around in the snow trying to stay nice and dry.
GmtGmt is offline   Reply With Quote
Old 05-23-2011, 12:29 AM   #13
jimbonice
jimbonice's Avatar
Re: Overheating?
Just drain a gallon of coolant out before you pull the thermosat housing off. There won't be much mess.
Old 05-23-2011, 01:35 AM   #14
pig rig
pig rig's Avatar
Re: Overheating?
if its only over heating when its at idle its not your T stat its you clutch fan
if it was your thermostat it would over heat when your going down the road because the thermostat will stop all water circulation as were a fan not spinning at idle wont pull enough air through the rad to cool the slow circulating water
and if you still think you need a thermostat dont put a low temp one in like a 160' keep a 190' in it the lower temp stat will screw with the ECM on a tbi engine and you'll fight to get it to run right
my sports car rolls on six wheels only because I'm to fat to get in and out of new corvette
http://hubgarage.s3.amazonaws.com/ph...ped_detail.JPG
pig rig is offline   Reply With Quote
Old 05-23-2011, 01:50 AM   #15
DetroitDan
DetroitDan's Avatar
Re: Overheating?
anybody else worried about his water pump? I agree with the clutch fan diagnosis, but I'd question the water pump too, it's old enough to go.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop.
DetroitDan is offline   Reply With Quote
Old 05-23-2011, 09:26 AM   #16
thirdstreettito
Resident of Here
Re: Overheating?
I was actually thinking it might be good to buy the pump, clutch, and t-stat. Especially because I dont know what she'll do when towing in 100* heat.
~Bradley~
Miss having a truck
Old 05-23-2011, 10:19 AM   #17
Eyegore
What Hump?
Eyegore's Avatar
Re: Overheating?
I would I agree about the clutch but also check your radiator, when was the last time it was flushed? Here in Phoenix it is usally the first thing I always check.
Lil red 86 c-10
99 Sub
78 Camper Special w/ 454
Eyegore is offline   Reply With Quote
Old 05-23-2011, 11:52 AM   #18
jimbonice
jimbonice's Avatar
Re: Overheating?
This is all good advice. Also, it never hurts to throw a timing light on it as retarded timing will cause it to overheat.
Old 05-23-2011, 03:49 PM   #19
thirdstreettito
Resident of Here
Re: Overheating?
Thanks guys. Idk when it was last flushed, probably within the last 2 years as it was a rescue truck.
~Bradley~
Miss having a truck
