Old 05-20-2011, 11:26 PM   #1
lt704
upper steering colum bearing
Hi Folks, I have a question concerning my steering colum. I have movement in my steering wheel ( a little play). I took off the wheel and the turn signal switch. I have the movement where the shaft comes through the upper bearin, everything is tight. Would a new bearing take care of the slopiness? Should there be any movement in my steering colum where it goes through the bearing? Thanks for the help...Russ
1968 Chevrolet C-10 2 wheel drive
Lil' Red
In life always try to make a difference
lt704 is offline   Reply With Quote
Old 05-21-2011, 12:27 AM   #2
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: upper steering colum bearing
when you say sloppy are you talking about the play in the wheel turning or play movement up and down > i would think if the play in the wheel is from turning i would adjust the steering box worn gear ,its possible its worn out ,
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 05-21-2011, 12:31 AM   #3
leddzepp
Moderator
leddzepp's Avatar
I agree.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 05-21-2011, 08:07 AM   #4
lt704
Hi guys, sorry about not being clear. The movement is up and down. Everthing else is nice and tight. What i should have asked is should there be any movement where the colum runs through the upper bearing in the colu,??? I hope this helps...thanks Russ
Lil' Red
Old 05-21-2011, 11:03 AM   #5
68gmsee
Active Member
68gmsee's Avatar
I'm no expert but if I remember correctly, the column is spring loaded by a spring on the engine side with a clamp. I believe you can adjust this clamp.
68gmsee is offline   Reply With Quote
Old 05-21-2011, 02:16 PM   #6
67Slider
67Slider's Avatar
^ Yup. I just had to do this too. I had a bit of play after installing the power steering. Loosen the clamp at the upper part of the steering shaft, I had my 9 year old push the wheel so it wouldn't just back out, tap the whole assembly towartd the sterring wheel. You should see the spring compress and then tighten everything up. No more play.
67 C10 Stepside
66 Mustang Coupe
99 Burb 2500
67Slider is offline   Reply With Quote
Old 05-21-2011, 02:18 PM   #7
77chris03
77chris03's Avatar
ok, so the shaft is suppose to float? im redoing my column and not installed yet but when the shaft floats and i have new bearing, cam, etc.
68 C10 Stepper #1- GONE 68 C10 Stepper #2
1977 Chevy Cheyenne...gone...was my first Chevy
04 Tahoe Z71, 04 Silverado 2500HD, 04 Sierra 2500HD
99 Sierra Stepside, 17 Denali HD, 84 K10
My 1st build-- http://67-72chevytrucks.com/vboard/s...d.php?t=379333
My 2nd build-- http://67-72chevytrucks.com/vboard/s...d.php?t=700310
77chris03 is offline   Reply With Quote
Old 05-21-2011, 09:53 PM   #8
lt704
hi Guys, Thanks for the imput. When you folks are talking about the spring loaded clamp?, is this the clamp that is on the engine side of the firewall?? Are you talking about the clamp that has a bolt that goes around the colum? I made sure that it was tight, where is the spring? thanks for the help...Russ
Lil' Red
Old 05-21-2011, 10:02 PM   #9
cpisani70@aol.com
cpisani70@aol.com's Avatar
I recently replaced both the upper and lower bearing in my column what difference and the low was the worst of the two. I would say change them if you have doubt.
cpisani70@aol.com is offline   Reply With Quote
Old 05-21-2011, 10:55 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Yep. As I mentioned on my post it's on the engine side.
Scroll down on this posting and you can see the clamp and spring.
http://67-72chevytrucks.com/vboard/s...d.php?t=270062
Old 05-22-2011, 08:36 AM   #11
lt704
Thanks everyone for the help. I just ordered the bearings. You folks are the best...Russ
Lil' Red
Old 05-22-2011, 09:56 AM   #12
Wrenchbender Ret
The lower brg. is supposed to float from the spring pressure & take up the slack. They usually get stuck to the shaft over time. You have the right idea. Replace them both & clean up the shaft.
Wrenchbender Ret is offline   Reply With Quote
Old 05-22-2011, 02:33 PM   #13
lt704
I found the clamp and spring. thanks again everyone. you sure do learn alot from the guys on this site...Russ
Lil' Red
Old 06-08-2011, 08:51 PM   #14
lt704
Update on my upper steering colum bearing. After a couple weeks of having movement in my steering wheel the problem has been found and fixed. I put a new upper bearing and had the same problem. The steering shaft came through the bearing tight but the bearing itself still allowed the shaft to move. When i put a 1994 s-10 steering wheel it came with a new turn signal cancellation cam, I used the new one. our 68 trucks cancellation cam is beveled that fits tightly onto the upper bearing. The 1994 cancellation cam does not have a bevel, so thats why i had the movement. I put in the 1968 correct cam and all is well. Sometimes you just have to keep on trying....Russ
Lil' Red
