Old 05-21-2011, 01:57 AM   #1
bigdon-70blazer
Shift lever out of 4 speed
Is there any easy way to get a shift lever out of a 4 speed from the top after I get the hump cover off without disassembling the entire thing? Is there a trick or what? I am trying to get out 2 before the trucks are crushed...
bigdon-70blazer is offline   Reply With Quote
Old 05-21-2011, 02:02 AM   #2
71/454
Turbo Guy
71/454's Avatar
Re: Shift lever out of 4 speed
Pull the boot. I use channel lock pliers opened up about an inch and use the jaws to push down on the inner part of the ball metal lookin thingy that the stick goes into. Push it down and turn counter clockwise and it should pop up
1972 Gmc Custom swb intercooled twin turbo 327 10.5-1 and 12 lbs of boost, Nodular iron case super t-10 4 speed with a blowproof bellhousing, 12 bolt eaton posi soon to have moser axles.
1998 Honda CR250 fully ported, case matched, milled head, vortexed carb and revalved suspension but don't forget the woody woodpecker decal kit!
Things I've broken so far:
12 bolt diff
saginaw 4 spd many, many pieces
Aluminum case Super t-10 4 spd
71/454 is offline   Reply With Quote
