Sending unit wiring for LMC rear tank
I recently bought a rear mount tank for my 65 from LMC (big mistake)and I need to find the wire connector that snaps on the sending unit stud. The original tank unit had threads. Any ideas where to get one. Thanks
Re: Sending unit wiring for LMC rear tank
Can't help with your search. But why was LMC rear mount tank kit a big mistake? poor quality?
Well a combination of things. Poor quality, its very thin, the neck is only 1-3/8" diameter,too small for a fill hose. It mounts in the holes that are there just fine but the neck is right where the cross beam goes. I actually slid mine toward the back as far as it would go and drilled new holes. That way the filler hose clears, the vent line now is right at the cross beam but its small enough to get around it since you have to notch it the whole width frame rails to clear the tank. They should make the neck in the rear corner and make the tank 18 gallon instead of 21 so you dont have to trim the cross beam so it doesnt hit the tank or you can use some 2" spacers to so the tank sits 2" lower. They should also include a piece of hose and sending unit wiring. They sell it as a kit but you have to do alot and buy alot for the $200 "KIT" to work. I bought several other things as well. Mirrors look good but are cheaply made. Front fenders are paper thin. Wiper assembly ok and door handles and grill trim are ok. almost afraid to get carpet set now. I hate to bash them its just that I expected better quality for the money. I may have visit the junk yard to find the sending unit button. I took a male crimp on wire connector and tapped it down on the stud for now but need perminant solution. Thanks for the reply
i know i aint shopping there any longer they also sended me a crappy buttom section fender panel i orderd
#5 | |
My search for decent rear half fender panels continues. |
Check out the "Review Board" guys: http://67-72chevytrucks.com/vboard/f...splay.php?f=26
If you look in the "Bad Deals" sub-forum you can learn from others misfortunes. |
