Old 05-21-2011, 06:38 PM   #1
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Finally got the '76 Running again.
Had it running initially a week ago, decided to switch the cam and intake around for a different setup. Idling at 1200rpm.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily.
04 Pontiac GTO
04 Ford Mustang GT
68 C20 LWB stripper truck
73 K5 Cheyenne
76 C20 Sierra Crew SRW
88 K20 Suburban
I'm not hammering on metal just to hammer, i'm creating a piece of art.
1BadSS is offline   Reply With Quote
Old 05-21-2011, 08:13 PM   #2
3r!c84
Badass
3r!c84's Avatar
Re: Finally got the '76 Running again.
bring the idle down to like 600-700 rpm will sound great!
Think outside the box?
-84c10 (1stcar)→My Build
-00 Saturn 5spd
drop a gear and disappear!
1/4:13:90
3r!c84 is offline   Reply With Quote
Old 05-21-2011, 09:04 PM   #3
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Man, thats way too low of an idle!
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 05-21-2011, 09:24 PM   #4
3r!c84
Badass
3r!c84's Avatar
with your timming set up right and carb working good.800 and600-700 in gear is nothing un common. 1200 is way to high even in park
-00 Saturn 5spd
1/4:13:90
Old 05-21-2011, 09:47 PM   #5
MrMFFB
idle speed hot in gear 600 rpm, 800-900 rpm cold in gear
MrMFFB is offline   Reply With Quote
Old 05-21-2011, 10:05 PM   #6
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
With the way you said it, you seemed to mean 600-700 in park.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
Old 05-21-2011, 10:07 PM   #7
3r!c84
Badass
3r!c84's Avatar
Lol well mines that low
-00 Saturn 5spd
1/4:13:90
Old 05-21-2011, 11:51 PM   #8
f.monroe
f.monroe's Avatar
Sounds a bit rowdy . I like it .What cam is in it ? Have you hooked up the torque converter yet? Doesnt sound like it . If not it will definitely tame it down a little.
I used to have a 77 in highschool that I drove for a while with the same exhaust setup. Only diff was that I had Dynomax Turbo mufflers. That thing was unbearable at 35-45 mph in drive.
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 05-22-2011, 12:06 AM   #9
1BadSS
NOT REALLY BANNED!
1BadSS's Avatar
Frank
Frank, Torque converter is hooked up. It's a summit 1107 cam.
The plan is to run tailpipes out the back. Thats still in the works though. As I have to drop the bed, detail the chassis, install the flip kit, the front drop springs. Button all of that up. R&I the rockers, cab corners and install the new doors, fenders, hood and core support.
04 Pontiac GTO
04 Ford Mustang GT
73 K5 Cheyenne
88 K20 Suburban
