Converting to a big block which booster should I use?
I've got a 72 Blazer that I'm restoring and I'm getting ready to go through the brake system.
The truck came with a 307 but I'm going to put a big block in it. Which booster should I use for room? Would the stock booster be ok or should I get a smaller dual diaphragm booster? If I should go away from stock which booster should I use and which master cylinder should I use? Will the stock master cylinder mount up the the dual diaphragm booster? Will the dual diaphragm booster mount up the the firewall and brake pedal? |
Re: Converting to a big block which booster should I use?
Anyone?
I have a b.b in my 78 with roller rockers and tall valve covers and you can,t remove the valve cover with the stock booster.I,m looking at the 7 in. one from summit but not sure if is a direct bolt in or not.I,m also thinking of no booster,my 80,s truck has no booster and it seems to stop just as good as the other truck
