05-21-2011, 10:54 PM | #1 |
Axle ID and disc brake question
I was wondering if anyone can give me an idea on the rough year this axle is ? it came with the truck I bought and don't have a clue for the year. The previous owner had it overhauled and put quite a few bucks into it but I haven't cracked the case yet to find out the gearing
I know it's a chev 10 bolt with a casting #1254333 likely from a 2nd gen f body or S-10, but I think the disc brakes are an add on from the previous owners build... this will be going into a lowered 55 GMC with a camaro front clip BTW the main reason I'm asking is that I'm pretty sure the location and style of the parking brake cable is going to have a clearance problem with the rims I was looking at 17-18" and the tire width/ back spacing. I'm curious if I can change the disc brake setup for a style with the internal drum for parking and outer disc for the brakes without running into 5 other changes that have to go along with it. also the one brake fwd and one rear doesnt appeal to me either, I'd rather have them top rear any sugestions or experience with this type of swap without buying a $800 kit, I'd like to stay with off the shelf chevy parts |
05-22-2011, 05:12 PM | #2 |
67-72 parts collector,…
Re: Axle ID and dics brake question
Anyone???
05-24-2011, 01:51 PM | #3 |
I tried to do a search but still haven't found the answer, I'm amazed that this hasn't come up before so I guess I'll have to rethink my question.... so... is there anyone using this same axle set up with 17" rims? if so what is the widest tire/ rim before you can use before you start rubbing the parking brake cable?
also does anyone know if there is a universal parking brake kit where the end of the ridged cable comes in at a slight angle say 20-45 degree? I haven't bought my rims and tires yet but don't want to waste time and money on something that won't fit |
05-24-2011, 08:42 PM | #4 |
Re: Axle ID and disc brake question
79 and 80 Firebird is my guess if it's 5x4.75. My Nova has this same set up on it from a 79 Caddy. The Firebird and the Caddy disc setup is the same except the Caddy is 5x5 plus the Caddy is coil sprung. Everything between the two seems to be the same, even the rotors except they are drilled the Caddy with the bigger pattern.
I have Caddy backing plates, calipers, master cylinder and prop valve from the Caddy and rotors from the Firebird. This is on my stock 8.5 Nova rear, everything bolted right on.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
