05-21-2011, 11:16 PM | #1 |
Putting plugs in a 5.3
This is the first time Ive ever worked on an alum head(surprising seeing how many engines Ive built)
Im a little worried about damaging the head since I have no idea if I can trust that the old owner put anti seize on the plugs or not...could it help any if I sprayed some pb blaster on the plugs and let it sit for a little bit before giving it a shot?? Or should I just make sure its cold and cross my fingers? Sorry, I know this is a stupid question to most of you.
smoke:2001 Silverado 1500 HD tranny cooler 285-75-16 E range Hankook M/T's, Helper springs, Trailerbrakes, Toolbox(with every tool ya need), Mudflaps, etc.. Its the farms mobile work shop: |
05-22-2011, 10:02 AM | #2 |
Re: Putting plugs in a 5.3
well i change alot of these out and never had a problem don't have to be changed till about 100k and the factory don't normally use anti seize and they come right out, be sure to use a good set of ac delco plugs like platinum or better
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube Last edited by truckdude239; 05-22-2011 at 10:02 AM. |
05-22-2011, 12:47 PM | #3 |
Changed them this morning, after some interesting pops and crackles from the NGK plugs, all is good.
05-22-2011, 02:23 PM | #4 |
did you take ngks out or put them in?
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
05-22-2011, 05:21 PM | #5 |
Took ngks out, put AC Delcos in..those pos ngks were soo burnt out Im surprised it ran
05-22-2011, 08:37 PM | #6 |
laying low
After having ruined threads in small engine heads before and having to use helicoils to save them when it came time to change the plugs in my LS engine I wasn't taking any chances. I waited until overnight to change them and used antisieze going back in. Helps lube the threads and maybe prevent them from gawling next time they come out. Cheap insurance.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
