05-22-2011, 01:10 AM | #1 |
Moderator
Seat Belt Buckle Cover Removal
For those who want to remove a seat belt buckle cover to replace it, or remove the belts to dye them, here are the steps to do so:
1. Tools: Small flat screwdriver and butter knife 2. Insert the screwdriver beteen the cover and the buckle. You will notice a small plastic tab on the buckle cover that fits into a slot on the buckle. 3. With the screwdriver still in place, insert the butter knife between the buckle cover and buckle--along side the screwdriver. Once the butter knife is inserted, remove the screwdriver. 4. Next, insert the butter knife in the same position on the opposite side 5. Once the knife is in place between the plastic tab and the slot in the buckle that it fits into, begin to carefully pry the plastic cover out of the buckle with the screwdriver. 6. Keep prying slowly until you see the buckle come out about this far: 7. Next, take the screwdriver and repeat the process on the opposite side. BE CAREFUL not to let the plastic cover re-seat itself back into the buckle, or you will have to repeat the previous steps. 8. Pry the second side out the same distance as the first side: 9. Once both plastic tabs of the buckle cover are free from the little slots in the buckle, pull apart. 10. You're done!
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 06-02-2015 at 04:27 AM. Reason: Adding Pictures |
05-22-2011, 01:24 AM | #2 |
Re: Seat Belt Buckle Cover Removal
70LonghornCST,
Thank you so much for taking the time to show and document that procedure. That was exactly what I needed. I will be using the technique tomorrow and will let you know how it comes out. I hope that others on the site find it as useful as I did. By the way, great pictures. |
05-22-2011, 01:31 AM | #3 |
6>8 Plugless........
Thanks for the detail write up and pics. Do you plan on doing one for dying the seat belts by chance?
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-22-2011, 01:35 AM | #4 |
I will be dying my recently purchased center seat belt. It is a little faded, so dying it will hopefully bring it back to that nice original black color.
05-22-2011, 01:46 AM | #5 | ||
Moderator
If you are dying black with black, they'll come out perfect! However, when dying a light color, like beige, they won't be an exact black match if you are using RIT dye. But RIT black dye works great on faded belts that were originally black.
70 Longhorn CST Build Adding an AM/FM Decal |
05-22-2011, 01:49 AM | #6 |
Where's the best place to get the dye at? Thanks Ryan.
05-22-2011, 01:59 AM | #7 |
Moderator
You can usually find RIT dye in many grocery stores or large drug store chains. Raley's, Safeway, CVS, Walgreens, RiteAid, or Walmart. If still no luck, try a fabric store.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 05-22-2011 at 02:00 AM. |
05-22-2011, 02:24 AM | #8 |
Laid Back
Have you ever dyed green belts black and if so how do the turn out
72 chevy swb Direct dealers for.. Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body.. Kyle http://67-72chevytrucks.com/vboard/s...d.php?t=574629 |
05-22-2011, 03:09 AM | #9 |
Moderator
Sorry, but no, I have not. However, based on how the beige acted when mixed with black, I would venture to guess that any dark color belt should turn out fine. It's the light colored belts that are hard to get completely black due to the dye not penetrating the fabric completely. I am sure that there is a dye out there that will do the trick for any color, but RIT is not it. If using RIT dye, make sure the belt is already a dark color. I will take some clippings of different color belts at the auto wreckers on my next visit and do some experimenting.
70 Longhorn CST Build Adding an AM/FM Decal Last edited by 70LonghornCST; 05-22-2011 at 03:10 AM. |
05-22-2011, 03:34 AM | #10 | |
Laid Back
05-22-2011, 08:09 AM | #11 |
Retired Air Force Veteran
This is a GREAT WRITE UP! THANKS 70LONGHORNCST. I inquired last week about this. I recently picked up a bench seat set (3) of parchment seat belts and plan to dye them black, hopefully, this up coming week sometime. I will take b4 and after pics. The RIT Dye is at the local grocery store as stated above for about $2.50 a box. The buckle removal procedure will make to outcome of the reconditioned seat belts so much nicer.
Again, Thanks A Staff Member should forward this to the FAQ Section.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 05-22-2011 at 08:10 AM. |
05-22-2011, 09:19 AM | #12 |
Dave's not here, man
Definitely!
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
05-22-2011, 11:35 PM | #13 |
70LonghornCST,
Worked just like the thread. I dyed my belt (twice) and with any luck will have it installed tonight. Thanks again. Brian |
05-23-2011, 05:07 PM | #14 |
Brian, how did dying it twice do? What color were your belts originally? I called RIT today and inquired on the light color fabric belts opposed to a darker color and it was suggested to follow the stove top directions but to use (2) packs of RIT dye instead of 1 with 3 gallons of water (I have parchment color seat belts). I'm going to dye mine over the weekend, i'll take before and after pictures. I am going to follow the procedures posted above by 70 LonghornCST for the buckle removal.
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors Last edited by myoldchevytruck; 05-23-2011 at 05:08 PM. |
05-23-2011, 05:27 PM | #15 |
WOW!!! Thanks for the easy removal procedures 70LonghornCST, a lil' patience and WALA.....All three are easily removed and no breaks, Amazing!
Harry 69' SWB Step Side 1/2 Ton w/68' Front Clip Swap from Leafs to Trailing Arms (Complete) Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front) 3/6 Drop Help Support The Board Click Here For Information On How To Subscribe Krue's FAQ Page Vendors |
05-23-2011, 05:28 PM | #16 |
Is there a specific way to dye these with the RIT dye. I've used it for dying clothes in the washer but never anywhere else. Thanks
Mike Currents: '74 Cheyenne Super C30 Camper Special 3+3 aka "Sucia30" Past: '79 C10 BIG 10 (Sold) 69 CST LWB - Always a "Work in progress" true work truck (stolen) 05 GSXR 750 it has a pretty paint job _wrecked 72 SWB full frame restoration -sold! 71 CST K5 Blazer 4x4 (soon to be 2wd)-project - sold! C10 Club 2012 Brothers Show Video http://youtu.be/pUeV2vP7Wpo |
05-23-2011, 06:40 PM | #17 | |
www.ritdye.com/dyeing-techniques/stovetop
05-23-2011, 08:23 PM | #18 |
Thanks for that link Harry!
05-23-2011, 08:48 PM | #19 |
Big Red - Now its a SWB!
I don't know how much truth there is to it, but I heard on another thread on here that it's not a good idea to heat the belts (stovetop method) because it can weaken them. Like I said I don't know if true or not, but figured that I'd throw it out there. At any rate let us know how they turn out, as I have mismatched seatbelts in my truck now and I've been considering dying them so they match.
68 3/4 ton (Project)-350 Small Block, .030 over, 10:1 comp, 3998993 heads, C3BX edelbrock intake, comp cams XE268, Holley 670 SA, long tube headers, dual flow 40's, E-fan, Alum rad, currently under the knife getting shortened and bagged build thread 41 3/4 ton (wife's)-flatbed, fully restored to original 01 Tahoe LT 4WD (my daily driver)-Magnaflow Muffler, Rollin on 22's 02 Ford Mustang Convertable (Wife's Car)-Flowmaster 50, Clear corners, Intake, sittin on 18's |
05-23-2011, 09:30 PM | #20 | |
Dying it twice worked good for me. I was only dying black on black. The belts I dyed were a little faded. With the first pass one of them came out kinda purple. After the second time it was good to go. I did not use the stove top method, but I added way more dye then the directions noted and just enough hot water to submerge the belts completely. Let me know how it comes out, I'm very interested. |
05-23-2011, 09:43 PM | #21 | |
05-23-2011, 09:59 PM | #22 |
I basically followed the directions on the bottle, but I use more dye and less water. Put the dye in a tub of very hot water and stirred it up. I also left the belts in the dye for a few hours. Hope it helps.
05-23-2011, 10:01 PM | #23 |
Thanks Brian, Hopefully by the weekend, I'll have mine done. I'll post b4 and after pictures.
06-02-2011, 09:13 PM | #24 |
I plan to dye my blue belts black. I will use a 5 gallon bucket of hot water. Do I have to wash them off with warm water when they are done?
06-02-2011, 09:21 PM | #25 |
start off with warm and then cold water. Run them under the water till the water is COMPLETELY clear to assure all of the excess dye has been removed
