Old 05-22-2011, 09:41 AM   #1
83 Silverado
83 Silverado's Avatar
Re-working stock engine harness
I'm looking to see who has taken it on. The info from lt1swap.com looks to be clear and well written, but I like to know if any one has used it for there swap's. I am about to start a 4.8l/4l60e swap in my 83, and I'm gathering info before I start.
83 Silverado is offline   Reply With Quote
Old 05-22-2011, 10:45 AM   #2
Notch1988
Notch1988's Avatar
Re: Re-working stock engine harness
The way I look at it is if you mess up really bad and turn the harness to garbage it is only a $500 fix.
There's a series of videos on youtube from some guys that show how to rework a harness...
Notch1988 is offline   Reply With Quote
Old 05-22-2011, 01:19 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The solution to any wiring problem./
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-22-2011, 02:12 PM   #4
Big Port Jimmy 6
Addicted to Rust
Big Port Jimmy 6's Avatar
I used the LT1 swap info on mine and have had no troubled with it and have close to 700 miles on the swap. Current performance offers a kit to help you make it stand alone and is cheaper that the stuff I bought to do it my self. The initial conversion took several hours on a Sat with nobody bothering me and a couple of hours later to finish it up in the truck.
http://www.currentperformance.com/Ac...ies/SA-1k.html
Jay
Current trucks:
(48 GMC100 320 inliner) Gone
(48 Suburban in pieces) Sold
87 GMC CCSB 5.3 4l60E Daily Driver
ECTA National record holder XO/PP
We never really grow up, we just learn how to act in public.
Big Port Jimmy 6 is offline   Reply With Quote
Old 05-23-2011, 02:33 AM   #5
5150.4.67
I too use lt1 swap for my harnesses. Very informative, but a little on the unorganized side. Still, I'm very thankful for his info. I even used the factory fuse block (huge) on one swap, completely overhauled it to suit my needs including all the truck body fuses and relays (that alone took many hours)...............
So go for it, take your time and don't cut any wires until you are ready to wrap it back up!
5150.4.67 is offline   Reply With Quote
Old 05-23-2011, 09:11 AM   #6
83 Silverado
Thank for the reply's, the fuse block from current looks like make for a clean looking install.
Old 05-23-2011, 09:34 AM   #7
Shon
I use the current performance fuse block. I also am a dealer for them so if you need a harness done or any of their products let me know.
71 Cheyenne C10 LWB cam'd 6.0/T56 Swap
Shon is offline   Reply With Quote
Old 05-23-2011, 07:24 PM   #8
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I did it pretty much like LT1 swap describes except I kept all of the fuses the engine uses. So I have 7 fuses instead of 4.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 08-17-2011, 12:43 AM   #9
mcbassin
Still Learning
mcbassin's Avatar
Jay
I am new to this LS stuff. I'm trying to modify my own 2003 harness. I have all the un-needed wires pulled from the blue and green connectors from the chart on LT1 swap.com.
How did you figure out what other wires from the c-1 connector need their own fuse(s)? I know the PCM and O2 sensors need to be fused but it seems like there are about 30 pink wires there? I don't have a diagram but do have the pinout chart. Not really sure what to do next? Also, do you guys check continiuty before taping the harness up? Below it was recommended not to cut any wires until ready for tape.....oops mine already had several cut when I got it.
I think the video done by the Alaskans is great. But I just don't know how you fellows know what to keep and what not to keep other than the pinout chart for the PCM.
I wish there was a step by step with pictures showing all the connectors and what they are and what needs to be kept.
mcbassin is offline   Reply With Quote
Old 08-18-2011, 09:50 PM   #10
Robznob11
Robznob11's Avatar
I done my own useing the lt1 site took about 6 hrs and 40 bucks worth of parts. sent to puter to wait 4 me performance for a reflash 75 bucks and it started as soon a i got fuel to the injectors. Idles like a kitten no problems
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 08-18-2011, 09:52 PM   #11
Robznob11
Robznob11's Avatar
this was my first start up! http://youtu.be/QWltob_2mLQ
<iframe width="420" height="345" src="http://www.youtube.com/embed/QWltob_2mLQ" frameborder="0" allowfullscreen></iframe>
LED TAILS
Old 08-19-2011, 12:49 PM   #12
duwem
duwem's Avatar
NICE, that thing sounds good.
Love the gauge cluster (I realize it was just to check up on the engine while you fired it)
duwem is offline   Reply With Quote
Old 08-21-2011, 10:27 AM   #13
Juiced06GTO
I also used lt1 swap for my info. The current performance fuse block looks nice, i built my own using the info on lt1swap, but I don't think the current performance one was available when I did mine. I drive the truck everyday and have probably 10k miles on the swap so far. Also used it to plow my driveway this past winter and everything is still going good. The only thing giving me fits is rust creeping up on the body, the vss stopped getting a signal, and it desperately needs an OD (4.10's with a th400 and 3's means 3k rpm on the highway!) Use the site its great just take your time.
Juiced06GTO is offline   Reply With Quote
Old 02-09-2012, 10:59 PM   #14
stealthy '69
'69 Chevy SWB
stealthy '69's Avatar
I'm of the same thinking. I learn better by doing the job or seeing pics at least. If I can only read about it, i don't feel like i learn as well.
Matt
'69 Chevy SWB Fleet, Primer Black; Project No Name
'06 Chevy Trailblazer, Blueish Silver?; Wifes DD, Sold
'08 Chevy Impala SS, Silver; the new DD, AND IT IS FUN!!!
'99 Dodge Dakota R/T, Intense Blue; DD, Sold
Originally Posted by longbed67 View Post
The tig welds are not the prettiest i have seen but they do have good penetration.
Originally Posted by oldblue1968chevy View Post
There are two things in life where penetration is really important.....and one of them is welding.
stealthy '69 is offline   Reply With Quote
