Power steering Pump
Hey Guys,
Im a newbie to the fourm, truck, and power steering. Ive owned my fair share on non power steering vehicles, and I decided to get power steering on my "new" c20. the belt is extremely loose and I need to tighten it in order to turn (found that out the hard way). Can someone walk me through the steps? Im a youngin starting a rebuild so you'll be hearing from me often Much apperciated, B |
Double 6's
Re: Power steering Pump
Should be an elongated hole in the top bracket that mounts the pump to the motor, loosen the bolts a bit, push till the belt is tight and tighten everything back up. May have a worn belt, so check that too.
Welcome to the forum and to the addiction!
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
