05-22-2011, 06:37 PM | #1 |
69' Chevy Stepside
New Track Time for my 69' C10 with LQ9 6.0L LSx Swap
Well I went out to the track yesterday and got some first new times for the new motor built in my 69.
The second run was the best at a 13.54 second 1/4 mile @ 100 mph. The tune is pretty rich so I think its got a bit more in it as well as headers and air intake upgrades. In truck camera: Outside camera: The engine is a LQ9 bottom end with L92 Heads, and an LS3 intake with 90mm TB. It also has a comp cam. I was pretty happy with the time but I think its still got more in it.
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver |
05-22-2011, 06:48 PM | #2 |
Re: New Track Time for my 69' C10 with LQ9 6.0L LSx Swap
Dang!! Your truck looks and sounds sharp!! Nice run as well.
05-22-2011, 08:08 PM | #3 |
hell yea, that nice!!
Truck sounds really good too!! It def has 12's in it, what tire are your running? it has significant wheel spin so if you can get your 60' down the big number will FALL. I figure the truck should be making at least 415-430 rw, through a 60e? have you had it dyno'd? I know it should make enough power to go 12's...good luck, looks like a fun project!! |
05-23-2011, 09:19 PM | #4 | |
69' Chevy Stepside
-Matthew -69' Chevy Custom/10 Shortbed Stepside 2WD "Copperhead" - Restored, 6.0L LQ9 Built. L92 Heads and LS3 Intake with Comp Cam 223/231 .610/.617 112 LSA, 4L60E with Shift Kit and Circle-D 3200 Stall Converter ~Build Thread -1957 Chevy BelAir 2 Door Post Sedan, Full Frame off Restoration done myself - 6.0L with T56 six speed -1957 Chevy BelAir 2 Door Post Sedan - Nearly rust free AK car, Project in the waiting -2003' Chevy Silverado SS AWD 6.0L! - Daily Driver Last edited by matthew20061; 05-23-2011 at 09:19 PM. |
10-04-2011, 10:48 PM | #5 |
nice ride! I am in the process of building a c10 right now, doing a budget turbo 5.3 setup.... your times even with the wheel spin give me hope of making my goals! Yours has so much more in it!
What are you running for suspension? You dont happen to know my buddy Kyle Q. with a black trans am do you? He lives there in Anchorage also... |
10-04-2011, 11:45 PM | #6 |
Sheetmetal Psycho
I love the sound! I get a kick out of the ashtray opening under acceleration
I didn't say you were stupid, but I was thinking it... I need a check up from the neck up! Project "Rigginstine's Monster" 1971 C-10 longbed 355/4spd Future mods: 67 front clip Webby's Rigginations - where everything has potential! |
10-05-2011, 12:26 AM | #7 | |
69' Chevy Stepside
10-05-2011, 08:49 AM | #8 | |
Sounds like you can make up alot of time in your trans tune too, is torque management still enabled? Sounds like it is but hard to tell, and did it go into overdrive before the traps or did you let off the throttle?
68 SWB Fleet 383 |
10-05-2011, 12:05 PM | #9 | |
69' Chevy Stepside
10-05-2011, 05:25 PM | #10 |
Grand PooBaa Member
That was a cool run.
10-06-2011, 07:01 PM | #11 |
Champagne Taste on Beer Budget
Very cool.
Looks like its COLD up there already huh? Good luck next season!
Coming Soon: Project 1970 Country Truck |
10-06-2011, 08:00 PM | #12 |
What gears are you running? It looks like there is quite a bit of potential for improvement.
I am hoping to run high 13s in mine when I get it to the track on some slicks. We'll see though. |
10-06-2011, 08:10 PM | #13 | |
69' Chevy Stepside
12 Bolt Posi 3.73 Gears is what it is running for the rear end. I ran the truck on a base tune my tuner sent me to get it up and running so I am sure with this new one it will run even better!
10-06-2011, 08:25 PM | #14 |
Man that gives me a lot of hope like to know what suspension your running.
71 Chevy C/10 lwb 350 5 speed nv3500 3.73 rear end 2.5" Front Drop and 4" in the back Edelbrock perfomer rpm manifold Edelbrock 600 cfm carb Headmen headers |
10-06-2011, 09:33 PM | #15 |
69' Chevy Stepside
Stock suspension! LOL Its lowered with CPP drop springs and shocks other than that its stock and seems to hook up pretty good just needs some slicks and I'll be in the 12's! Haha
10-07-2011, 12:58 AM | #16 |
Nice truck ! Looks like that was a fun time on the track
72 C20 Longbed 05 1500 Z71 |
10-07-2011, 01:05 PM | #17 |
Put a cover on your box, or bed, whatever you want to call it. That thing is like a parachute on it's side as far as drag is concerned. I'd be intrested to see back to back times with that thing coverd and then uncoverd. I'm thinkin the difference would be signifigant. Opening or removing the tailgate would be easy and free also.
I got a bench seat baby, you don't have to sit over there. |
10-07-2011, 02:38 PM | #18 | |
Just a car guy
Remember the tailgate nets that improved milage? Didn't work. However, opening the tailgate will move a bit of weight farther back and help with traction. Not much on these trucks, but some of the el caminos that had big heavy tailgates will see a big improvement on the track. Great looking truck! Great engine setup, was thinking about the same for my camaro.
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
10-07-2011, 02:52 PM | #19 |
~Rest In Peace~
diffidently need slicks,i like the color of the truck ,sweeeetttt
did you use the go pro camara ?
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
10-07-2011, 03:35 PM | #20 | |
68 SWB Fleet 383 |
10-08-2011, 03:36 AM | #21 | |
69' Chevy Stepside
Yeah... definitely agree tailgate had very little gain and same with the bed cover.
12-15-2011, 06:54 PM | #22 |
Off topic, but I have ran at that track when I was stationed at ft Richardson a few years ago. Track prep wasn't the greatest, but it sure is in a pretty area.
Posted via Mobile Device |
