Old 05-22-2011, 07:34 PM   #1
jessewebb
jessewebb's Avatar
lower ball joints, help
Hey guy's I took my 69 C/10 to have the front end alligned. Guy tells me I need new ball joints. So I've been online, advance,autozone and napa. every one I've tried so far is shorter that the one I took out. In shorter I mean, I can barely get half a nut on the ball joint, it doesn't come through the spindle far enough to get a cotter pin back in it. The old one had plenty of room to put a cotter pin in and tighten the nut with some threads sticking through the nut... Whats the part number I need or where can I get these bottom ball joints. Oh I tried a 72 model it was long enough to get a cotter pin in, but the ball joint was to small to stay in the bottom a-frame. I need help
Pete
The worst I ever had was wonderful
69 SWB work in progress
97 Ranger 6in. lift on 35's
04 325i lady's ride
jessewebb is offline   Reply With Quote
Old 05-22-2011, 07:46 PM   #2
bmfm64
bmfm64's Avatar
Re: lower ball joints, help
They are press fit so you have to get the stud through the spindle and seated. Have you layed them next to each other and made sure they are really shorter than the old ones?
bmfm64 is offline   Reply With Quote
Old 05-22-2011, 07:56 PM   #3
jessewebb
jessewebb's Avatar
yea I'm getting the ball joint up in the bottom a-arm housing, where its suppose to be. It's the threads don't come through the spindle far enough to get enough of the nut on it to put the cotter pin in. the older ones are long enough to get the cotter pin in. I just don't know what else to do
Pete
04 325i lady's ride
Old 05-22-2011, 09:27 PM   #4
Lee H
Lee H's Avatar
You have a swapped front end. Take the old joint out and try to match up. Don't be surprised if the auto parts people don't want to help out. You'll have to find someone willing to work with you.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 05-22-2011, 09:54 PM   #5
jessewebb
jessewebb's Avatar
I think you hit the nail on the head Lee H. Guess I need to find a mom and pop owned parts store that has the knowledge to get a part without having to pull it up on a computer and tell you, this is it... Thanks for your time
Pete
04 325i lady's ride
Old 05-22-2011, 10:11 PM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
You have 2 choices.
67-70
71-87
It's got to be one or the other.
What spindle do you have?
(I can't remember)
Keith
Convert to disc brakes.
Old 05-22-2011, 10:40 PM   #7
72lb4x4
Disk? Drum?
5, or 6 lugs?
I think a 69 would originally be drum and 6 lug.
72lb4x4 is offline   Reply With Quote
Old 05-22-2011, 11:51 PM   #8
ERASER5
ERASER5's Avatar
Originally Posted by 72lb4x4 View Post
Disk? Drum?
5, or 6 lugs?
Correct. If it is original, it will be 6 lug drum only.
Most aftermarket disc brake spindles are set up for 73-87 parts.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 05-23-2011, 12:08 AM   #9
lolife99
lolife99's Avatar
They use to be just,... 73-87 spindles.
Now you can get:
60-62
63-70
71-72
73-87
No need to change balljoints and tie rods anymore.
If I remember correctly,... the OP has disc brakes up front,... but I could be mistaken.
Keith
Old 05-23-2011, 07:19 AM   #10
jessewebb
jessewebb's Avatar
Its been changed over to 5 lug disc's on the front. Hard to tell what model it would be. I do know its not a 72 cause the ball joint is to loose in the a-arm. napa guy says they show the same part number from 67-72, already know thats wrong. got the one for a 72 at advance, they ordered another one for a 69, said that looked like it. dude at autozone had one for a 72 and couldn't read a mic, handed it to me. yea its to small. I bought a nos from brothers for the top it was for a 72, only had the one though got the other one at napa. Napa seems to be as close as I can get. I went on there web site, They actually show two different lower ball joints for a 69. So I ordered both of them. Don't know why the guy's computer at NAPA didn't show that. The biggest problem I've found none of the parts store stock any parts for the truck, you cant match anything up. All I can get is a picture. Eventually I'll get it figured out, Can't give up gotta "keep on truckin" Thanks for all the help and info guys.
Pete
04 325i lady's ride
Old 05-23-2011, 07:31 AM   #11
lolife99
lolife99's Avatar
The lower balljoint hole in the a-arms are the same size for all 1/2 ton 67-87 a-arms.
(only 3/4 ton lower a-arm ball joint holes are bigger)
Maybe the hole in your a-arm is wore out or "egg shaped".
Ball joint are as follows:
Upper:
67-70
71-72
73-87
Lowers:
67-70
71-87
If your upper is a 72 balljoint,... the lower would be a 71-87.
Keith
Old 05-23-2011, 08:18 AM   #12
jessewebb
jessewebb's Avatar
Probably something simple. I had to press the ones for a 69 back in though. Thanks
Pete
04 325i lady's ride
Old 05-23-2011, 08:58 AM   #13
70cst
70cst's Avatar
Good info guys
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-31-2017, 12:22 AM   #14
kpc01
Upper:
67-70
71-72
73-87
Lowers:
67-70
71-87
I know this is an old thread but by chance does anyone know if the hole for the 62-66 ball joints is the same size as the newer ones?
kpc01 is offline   Reply With Quote
Old 01-31-2017, 06:56 AM   #15
GR8-68
GR8-68's Avatar
I am pretty sure it is the same as the 67-70
Larry
It is easily overlooked that what is now called vintage was once brand new.
"Project 68"
paypal.me/ldgrant
GR8-68 is offline   Reply With Quote
