What's This Connector?
I had my gauge cluster out today and noticed this wiring connector behind it that had nothing plugged into it. It looks like something was plugged into it at some time in its life, but I don't know what its for. It has 2 terminals in it, 1 wire going into the right terminal, and 2 wires going into the left terminal...Can anyone identify what its for? Or what's supposed to go there?
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB Last edited by BigRed76; 05-22-2011 at 10:46 PM. |
Re: What's This Connector?
Nobodys ever noticed this connector hanging behind their gauge cluster? I'm sure everyone elses trucks actually have something plugged in there so its less obvious...lol
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
A larger pic might help.
Here are some better pictures...
I've never seen that. I could give you a guess and say horn relay but I don't think thats correct. Do the wires go into the rest of the harness or did somebody add it on.
Maybe trailer brake unit that used to be in there. I would think that would be farther down though. Just throwin stuff out there
Its not horn relay because I had to replace that so it is present. The wires go right into the factory harness that is all taped up, so it doesn't look like anything that was added on.
If you can get a wiring diagram for your truck and look for those wire colors you might track it down. From the newer looking tape on the end it looks like it might be an add on. I would guess aftermarket stereo or ignition lock or remote keyless entry. I had a Viper keyless installed on my truck and the connector looks like that (somewhat). If you don't have keyless entry I would check it out - I am spoiled and would not be without it now.
Slots go on anything!
Looks like it might be for the warning buzzer.
1974 Jimmy- 5.3/4L80e/NP241 |
Never thought about that, but now that you mention it the warning buzzer has not worked since I've had the truck. But I'm ok with that
![]() Posted via Mobile Device
which would explain why it is missing. I recall when they first started putting warning buzzers in everything people were so annoyed by them they unplugged them and threw them out.
Outside of that, we'll have to wait until Keith sees this, he will know.
1982 Chevy K30 CCLB fleetside. Formerly a cab and chassis, now a fleetside dually with the rear wheels tucked underneath. 454/th400/np205/C14/D60, 6/4 inch LIFT, not drop. |
| Bookmarks |
