Old 03-29-2003, 08:33 PM   #1
72gmcshorty
72gmcshorty's Avatar
Question Changing Vent window felt....
When I change the vent window felt, do I have to remove the tiny metal strips that hold the origional felt in place? If I do have to remove them, do i have to put them back in when I put in the new felt? Thanks.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 03-29-2003, 09:33 PM   #2
JimKshortstep4x4
Talking
We remove any extraneous materials and then glue the replacement strip in using 3M Trim Adhesive.
Jim
Old 03-29-2003, 10:50 PM   #3
Blue Beard
Blue Beard's Avatar
I was to understand that there are some rivets to drill and replace also..........any truth to this...............?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 03-30-2003, 12:57 AM   #4
dmurphy68
(rivets to drill and replace )
I just did this, you only have to do this if you are changing all the weather stripping on the vent window and it is not fun. Last rivet i put in is the first one i got to look right lol
Darren
The very atmosphere of firearms everywhere restrains evil interference. When firearms go, all goes, we need them every hour.
- George Washington
No free man shall be debarred the use of arms
- Thomas Jefferson
Later Darren
http://www.myspace.com/dmurphy68
dmurphy68 is offline   Reply With Quote
Old 03-30-2003, 07:47 AM   #5
JimKshortstep4x4
Talking
We never change the full channel, only the felt strip. We use a linoleum knife to cut the fabric away from the beading and the old felt will pull out, there is some scraping and detailing to be done so that the old channel is clean. Once the channel is clean we glue the felt in. Stays in forever!
If you change the metal channel, then riveting is definately needed. The channels are usually good.
Jim
Old 03-30-2003, 02:56 PM   #6
72gmcshorty
What about those tiny little metal strips that run along the edge of the channel? Do they have to come out or stay in place?
1992 Gmc 2wd
Old 03-30-2003, 03:15 PM   #7
dmurphy68
I took mine off and used some 3m to secure the new window felts
- George Washington
- Thomas Jefferson
Later Darren
Old 03-30-2003, 08:48 PM   #8
JimKshortstep4x4
Talking
GMCSHORTY,
I believe that you are talking about the little chrome beads that show at the outside. If you are then no, the beads stay. I can post a pic if you like tomorrow night.
Just take a knife and cut away the cloth parts, your new felts should fit in snugly so that the beading will still show.
When the original assembly was put together the beading clamped over the metal and the cloth securing the cloth to the metal, when you cut the cloth away the beading will be in place and you avoid the sharp metal that is covered up by the beading.
Jim
