Old 05-22-2011, 11:08 PM   #1
treveiger
treveiger's Avatar
8 to 5 lug conversion questions.
I'm planning on switching out my truck to 5 lug and had planned on putting a 79 front end on it but now the guy I had set up to buy the front end from seems not to want to deal with it and just take the cars to the crusher so I'm wondering what would be cheaper, waiting for a newer front end or using the a front end either from a 71 Chevy or a 71-72 gmc that I can get for free. Either way I'm planning on going through and rebuilding whatever one I decide to get and I'm wondering which would be cheaper and better to do? Any info on this would be great. Also if I switched to a 5 lug from the 71 Chevy or 71-72gmc what would i all need to do?
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 05-23-2011, 09:54 AM   #2
gcburdic
Restoration Virgin!
gcburdic's Avatar
Re: 8 to 5 lug conversion questions.
I've moved this over to the suspension forum....these guys are a big help over here.....in the mean time, have a look through this thread for more help on what's needed...http://67-72chevytrucks.com/vboard/s...=444823....BTW free is always good
Geoff with a G
1968 Chevy C10 SWB The Mistress
1972 Custom Deluxe C20 Suburban A Suburban Named Isabella
1966 Ford Mustang Mama's High School Graduation Present
gcburdic is offline   Reply With Quote
Old 05-23-2011, 11:42 AM   #3
N2TRUX
Happy to be here
N2TRUX's Avatar
Free is good, but not always the cheapest way to go. Since you plan to rebuild what ever you run, price the replacement parts. You will fimd that the 73-87 parts will save money in the end.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-23-2011, 11:50 AM   #4
treveiger
treveiger's Avatar
When I was looking the replacement parts for the 79 front end weren't much cheaper which I found odd but ill have to check around more. The front end of the 79 was $150 so I was wondering if it still would be cheaper. My truck already has disk brakes from a 71-72 I'm pretty sure but there 8 lug so I'm wondering if I just went with a 5 lug swap from a 71 or 72 what would I all need do.
Gcburbic thank you
Old 05-28-2011, 01:55 AM   #5
treveiger
treveiger's Avatar
Ttt
Old 05-28-2011, 02:06 AM   #6
lolife99
67-72 parts collector,…
lolife99's Avatar
Gcburbic thank you
What is the "big picture" plan?
Just get your truck to 5-lug the cheapest way possible?
Rebuild EVERYTHING?
We need a little more info.
Your 8-lug front end uses a different lower a-arm.
The upper a-arms are the same.
You will need to swap at the minimum:
1) all balljoints
2) lower a-arms
3) spindles
4) rotors
5) outer tie rods
Have you read any of this?
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Keith
Convert to disc brakes.
Old 05-28-2011, 12:47 PM   #7
treveiger
treveiger's Avatar
Pretty much the easiest an cheapest way for right now, and also inspect everything an rebuild if necessary. The truck was restored a few years ago and drives fine I'd just like to put my fathers old rally on there with a better highway rear end. Thanks Keith I was trying to find which way to go and couldn't decide.
