Old 05-22-2011, 11:38 PM   #1
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
DBW Pedal mounting
Anyone have pics of how they mounted their dbw gas pedal? I have the style with the large plastic pedal. I'd rather not mess with trying to cut or modify the plastic, but I don't have a flat spot on the firewall that lines up well. How did you guys do brackets?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 05-23-2011, 12:52 AM   #2
Gordonr1973
Home Built '87
Gordonr1973's Avatar
Re: DBW Pedal mounting
You should really read Dennis' build.
He has it detailed around post #1080 I think.
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 05-23-2011, 10:24 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Who is Dennis?
I have crazy ADD so I only read a couple pages at a time on builds, and I like to stare at the pictures.
Old 05-23-2011, 11:23 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Hey Br3, you must see the same doctor I do! I have the same diagnosis.....wait, I am not sure Dr. Pepper is his real name or not, do you know?
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 05-23-2011, 12:49 PM   #5
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Haha, the doctor is in! I try to stay away from caffeine... it doesn't mix well with the handful of narcotics my actual doctors have me on.
Old 05-23-2011, 01:33 PM   #6
usmcchevy
Has more rust than truck...
usmcchevy's Avatar
I'll have to let you know how my pedal turns out this weekend...I need to buy some more bolts.
1972 Custom/10 SWB, 4.8/4l80e
Build thread
LSx Swap FAQ index
usmcchevy is offline   Reply With Quote
Old 05-23-2011, 01:50 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Please do!
Right now it looks like I can build a small plate to attach to the firewall, and extend left to give me room to mount the potentiometer, but im a little unsure of how this will work.
Old 05-23-2011, 09:44 PM   #8
TR65
TR65's Avatar
BR3W,
Here is how I did mine. I didn't use the firewall, mounted off the pedal mount.
http://67-72chevytrucks.com/vboard/s...d.php?t=300335
TR
1965 C10 SWB Fleet
Two owner
LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880
TR65 is offline   Reply With Quote
Old 05-23-2011, 10:06 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks TR, with that style pedal, I can see how it would work. Problem is that I have the big plastic pedal.
Old 05-23-2011, 10:43 PM   #10
usmcchevy
usmcchevy's Avatar
Nice work TR.
BR3W, Yours looks kinda like mine....only yours has more of a curve. I have the bracket mine mounted to from the van. I put a bend in it to get the right pedal angle and will bolt it to the firewall using three bolts.
Mock up, only one bolt holding it right now.
Build thread
LSx Swap FAQ index
Old 05-23-2011, 10:50 PM   #11
TR65
TR65's Avatar
Well now I can tell you the rest of the story. The pedal I show in my thread would not work with my engine. So I wound up with a plastic thing too. I was able to make an angle bracket to mount it to the plate I had the other one mounted to. Here is a pic. It is not clear from your picture where the mounting holes are exactly on your pedal.
TR
1965 C10 SWB Fleet
Two owner
Old 05-23-2011, 11:41 PM   #12
ls1nova71
ls1nova71's Avatar
I made a plate with 2, studs welded to it, then welded the plate to the firewall over the three original mounting holes (welded them up too). Then put the firewall insulator back on, slid the pedal assembly over the studs and put two nuts on it, works good and looks good.
ls1nova71 is offline   Reply With Quote
Old 05-25-2011, 03:39 PM   #13
Hart_Rod
Hart_Rod's Avatar
This is what I did...
Hart_Rod is offline   Reply With Quote
Old 05-25-2011, 09:01 PM   #14
usmcchevy
usmcchevy's Avatar
Had a little time this afternoon. For the way it looks its surprisingly sturdy. 2 1/4" bolts and then the bent 5/16" bolt. Hope this helps.
Build thread
LSx Swap FAQ index
Old 05-26-2011, 09:31 AM   #15
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Thanks guys, it does help. I think my issue is going to be the big curve my pedal has in it. I'm going to use some time this long weekend to see if i can fab a bracket that will work.
